If i were to do that i would extend the liner off the bottom of the tee into the fireplace with a cap on the bottom then you could clean from the bottom easily.
Brilliant!!
If heat will convect to the upstairs from the basement then maybe consider an insert for the upstairs. That will provide a nice fireview and decent heat for milder weather or times when you don't need the basement stove/insert burning.
I have done 30 or so. It is pretty straight forward and it is reversible you basically just punch a hole through into the smoke chamber. The hardest part is hooking the liner up in there. Modifying the lintel is much more complicated and much more destructive to the fireplace.I've been searching for someone who has done a thimble-above-fireplace install, and I'm coming up empty.. The other thing I could consider is removing a couple bricks of the lintel; I may be able to get 6" of clearance below the smoke shelf...
Regarding an insert in either fireplace, I understand the theory is that the heat going into the chimney will eventually move into the living space. But the reality is that most of that heat is lost. The chimney is a massive structure, a tower of cinder blocks, a 4'x6' footprint extending from the ground/foundation, through three floors of living space, through the attic, and up onto the roof. It's gotta be over 40' tall. Several thousand pounds of cinder blocks that conduct heat to the cold ground and sky. It is covered by drywall through most of the living space.
So that's why I'm primarily interested in freestanding stoves. If the fallback plan was an insert for occasional weekend fireview, I would have a hard time justifying the investment of $5k for that without knocking down my heating bills.
How do you plan to build a truly non combustible hearth extension? To do that you need to remove the framing then pour and support a slab in it's place.So most stoves are too tall for my lintel. But why are they designed that way? Just for aesthetics,? Don't want a huge box sitting on the floor, and bending over to load it. The inserts sit directly on a non-combustible floor, which is what I would build out with my hearth.
We typically will use a combination of our arbor tech and a demo hammer and yes the smoke chamber is above the damper It may go above or below the mantle that depends on the situation. I would have to look at your to know.Do you have any photos? Do you punch out the bricks with a demolition hammer, or a cut them out with a concrete saw? Is the smoke chamber above the damper, but below my mantle? Or above my mantle?
Well that depends on the stove. To be clear most stove do not require this but you said about making the extension like the fireplace floor and putting a stove directly on it without legs. In order to do that you would have to have a truly non combustible floor structure meaning no combustible materials In contact with the bottom of that extension at all. Most stoves have specific requirements varying from simple ember protection with no real insulating value going up to pretty high R value requirements.I thought I could remove the wood flooring and replace it with half bricks or a granite countertop section. How thick dos it have to be to meet code?
Yes to be a true hearth extension for a fireplace that is what is required. But for a stove you only need to meet the r requirement of that said stove. It is very achievable for houses like yours but it is allot of work.They're saying the entire hearth extension must cantilever out from the chimney, so it is not supported by wooden floor joists?
Because they are on a fireplace floor which is truly non combustible not on a combustible floor covered with non combustibles.I'm not really interested in placing a stove on the floor without legs, but trying to understand why it is legal for inserts to do so.
If that is the case then your fireplace does not meet code. We actually had a customer of ours last month that we told his hearth extension was an issue have a fire under that hearth extension. His was 4" thick sitting on plywood and the floor joists. Enough heat transferred through to cause a fire.In my three-story colonial, the sub-flooring and joists supporting the heart/hearth extension are certainly combustible.
An open fireplace. But the same thing can happen with a wood stove that does not have the required floor protection under itwow, scary! Now was that from a freestanding stove with 8" legs, or another setup?
