https://www.usstove.com/index.php?route=product/product&product_id=510What stove are we talking about here?
Someone gave me about 5 cords of oak that was cut into mostly 16 inch logs and stacked for almost 2 years. I have been hauling it home and splitting it with my buddies 27 ton splitter. I think it needs some more time now that it is split... I have a magnetic thermometer on the stove top and the highest it has gotten when burning real good was 450 but usually hangs around 300-350. Is that even hot enough to burn right?
Hello all, I am new to wood burning and have recently purchased and installed a US Stove Company APS1100B EPA certified stove. I also installed the chimney which is a supervent insulated chimney system. I pulled a permit and had it inspected. The heat is fantastic! The stove is a little tricky to get going but once it is going, if you keep it hot and use smaller logs, it works well.
That being said, I have noticed lately that my lungs on some days feel a little funny. Could just be the dry air in the house, despite the cast iron kettle on top of the stove. I started researching wood burning health risks and am now quite concerned. I had no idea about the fine particulate matter and how harmful it can be. To help with ash, I bought a shop vac ash vac, which i feel is a bit of a rip off but I will see how it works. I know there are things like this that are heavily one sided, so I wanted to ask you folks, since you have much more experience with this.
Is it the ash or smoke that is the real worry? Is there anything I can do to protect my family? Is it safe once it is burning and door is closed? (Some environmental organizations say that 70% of the smoke particulates re-enter the home with doors and windows closed).
Wow, thank you all for the replies. I do not have a moisture meter but do think my wood is too damp. Someone gave me about 5 cords of oak that was cut into mostly 16 inch logs and stacked for almost 2 years. I have been hauling it home and splitting it with my buddies 27 ton splitter. I think it needs some more time now that it is split. I will have to invest in a moisture meter. I contacted the stove company to ask about the hard lighting and happened to ask if my stove has a secondary burn (doesn't have burn tubes or anything) and they said no. It is an epa certified stove though. I have a magnetic thermometer on the stove top and the highest it has gotten when burning real good was 450 but usually hangs around 300-350. Is that even hot enough to burn right?
Used to go 4 wheeling in the Pine Barrens...air is ALOT more clear down there then where I used to live....I'm on the southern end of the state near the pine barrens.
