I converted mine to a halon system, however I am finding it difficult to recharge the systemIf the stove gets to hot they spray water!
Just joking..others beat me to the answer!
A little elaboration....these inject heated air into the gases to burn off more of the smoke/gases. This is what makes the stoves burn more efficiently.A simple answer- those are the secondary combustion air inlets.
Wonder what would happen if we ran nitrous oxide into those tubes?A little elaboration....these inject heated air into the gases to burn off more of the smoke/gases. This is what makes the stoves burn more efficiently.
Sorta like a barbeque grill!ah, i see. they are for propane flue injection :D
That's right. What makes EPA approved stoves so efficient over older ones is that they are designed to burn a lot of the combustion products that otherwise would go up the chimney. Smoke, some gasses, etc. One way to do that is to put those tubes with holes at the top. They are supplied with air and get so hot that they burn those products. That's called secondary burning. Secondary burning is quite visible and adds to the light show. My wife calls them the afterburners.A simple answer- those are the secondary combustion air inlets.
There are separate inlets to do that job that are non adjustable.yeah, i have a lot to learn. and you folks are nice enough to help me.
were does the secondary air come from ?
Though some have found ways around that.
Just joking again!
