B
BrianK
Guest
Misleading. Japan's economic malaise is directly related to government debt.
There is a significant body of scholarly literature that would indicate otherwise.
I don't socialize anymore. Saves a ton of driving. I just live virtually now.![]()
I complimented my 11 year old 11 mpg truck with a 6 year old 40+ mpg car tonight. While it was primarily an economic decision, eliminating 800 gallons of needless fuel consumption a year also feels good. It also means that I will replace the consumption and maintenance of a 3 ton truck with a diesel powered car half its weight.
That's a valid point. On the other hand, Japan's economic malaise is directly related to their demographics. This is also, or will be soon, true of Greece, (broken link removed), and numerous other Asian and European nations.
Given current demographic trends, the "low" fertility assumption is by far the most likely, and even it may be too high.
By the way, since I'm in the medical field, "stasis" always has a negative connotation for me. "Venous stasis," "stasis dermatitis," "stasis ulcer," "gastrointestinal stasis," etc.
Spain is the global leader in green energy policy, industry and infrastructure. Its working out just swell for them.
See also The Myth of Green Energy Jobs: The European Experience
TDI? My BIL just got a '03 Jetta TDI and he's getting about 48 mpg. I'm jealous.
THe older (90s) ones did even better 55 Hwy 40s city. It seems new emission regs are the culprit.TDI? My BIL just got a '03 Jetta TDI and he's getting about 48 mpg. I'm jealous.
I've heard rumors about Riello burners running on 100% biodiesel. Depending on the year/build and a little pre-heating nothing is impossible.Hi JP11, how do you run your boiler on B65 biodiesel? I've read that more than 5% biodiesel in the mix is problematic for most burners.
1 gallon of #2 = 110 kBTU (output) = 32 kWh of elec.
At $0.15/kwh, it is matched to $4.86/gal
or $4/gal oil (about right for most folks factoring in service) breaks even with $0.12/kWh in resistance strip.
Sorry.. You lost me there for a bit!
This year my price is set to go up.... My source of bulk methanol is gone. I should have no problem staying well under 1.75 a gallon or so costs all in.
Electricity? It's not an option at all in Maine. I know of only a few houses that have it (most are a failed 70s experiment) and most of them add on something like pellets because of the expense.
I collect the grease on my way to and from work. I make the fuel while I'm working around the house. Just to make round numbers...
1000 gallons of fuel. 118k btu per gallon on my biofuel. So call it net 100k btu per gallon. 118Million BTUs for 1750 dollars. Compare that to 135million BTUs if it was #2 fuel for a cost of 3500 dollars today's cost.
Not sure how that would stack up to your electric prices.
JP
