We had 24.5 this morning, before the first fire the basement temp was 70 and the temps up here 66 & 67. The first load this morning was all pine.
Is that two splits per fire 😂. But were you warm?being cheap,only 2 fires with 4 splits in the last month.
"cheap"? Your wood isn't free?being cheap,only 2 fires with 4 splits in the last month.
If you have to much I’ll swing up and grab some"cheap"? Your wood isn't free?
Burning the stuff as fast as I can manage, I still fail to keep up with the rate at which my neighbors are dumping wood on me.
lol4splits ,ya took the chill out lolIs that two splits per fire 😂. But were you warm?
Sounds like you could benefit from something larger like a pe summit or something along those lines
Personally I feel running STT is too low at 400. Burn hot to keep creosote at bay. Burn hotter with a larger load and your house will warm up faster. Also you benefit from secondary combustion with a hotter burn. I have a small stove and burn between 550-625 STT. Heats 1,900 sq feet no problem.
Oh boy, someone’s in trouble lol**venting out of frustration**
SO wanted to clean up the stove area so so dumped about half bag of biobricks along with my half box of kindling. I came back home to 650F STT, bricks firing, and stove door cracked open - reason "it burns faster this way".
I guess I'm in trouble for leaving material around the stove. Somehow it's always my fault 😨Oh boy, someone’s in trouble lol
It never failsI guess I'm in trouble for leaving material around the stove. Somehow it's always my fault 😨
