- Jan 12, 2006
- 94
I have an eight year old Blaze King King KE1107. Last month I cleaned the Chimney and stove and every thing looked like all previous years. While I had the connector pipe off I checked the by-pass door gasket and saw that it needed to be replaced. As noted in a previous thread I used regular 5/8 inch rope gasket and could not get it to pass the dollar bill test. then I learned I needed the high density gasket, which is not available anywhere around here. I ordered some off the internet and it took two weeks to get some delivered. I installed the high density 5/8 inch rope gasket yesterday and got a very good seal on the by-pass door.
This afternoon I started my first fire, got a good base of coals and after a while loaded up the stove with about 7 or 8 splits (all oak at 16 percent moisture content and about 5X7 in width.
Here is my problem: The thermostat was on 3.5 when I put the splits in and every ten to fifteen minutes I would turn the thermostat down .5 (3.5--3.0--2.5--2.0--1.5--1.0). All previous years I would burn mostly around 2.5 and the stove top would be around 550 degrees.). No matter what I do with the thermostat, I can't get the stove top below 660 degrees...even when I turn the thermostat fully (pegged) counter clockwise! If I turn the thermostat up to 2.5 or 3.0 the coals will get redder and the temp will go up...but, turn the thermostat all the way counter clockwise and it will not go below 660 and I can hear a roaring draft through the connector pipe (double wall black). The cat combuster has glowed bright red consantly now for over four hours. All this I've never experienced before. Of the possible causes listed in the trouble shooting section of the manual, the only two that I can suspect is either the loading door gasket is leaking or the thermostat is bad. One thing very different with this fire than any other is that the door glass got extremely black in a very short time and has not burned off (even with the 700 degree temps.).
What is more likely the cause of my problem? Looks like I'll be staying up tonight to monitor this thing until I fill comfortable leaving it.
