Does anybody know what this would be?
What about new stoves sold today?
Are CAT stoves on the increase?
!!Webmaster said:There is something to be said about not having to load the moment you go to bed and again the instant you wake up.
In my experience that is not necessarily true. There are times when I reload my cat stove partway through a burn for various reasons. In general though for the longest burn, you need to start with a fresh load in a relatively empty stove. It is my suspicion that you can run a cat stove cleanly at a lower firebox temperature than a secondary burn system and therefore tend to acheive somewhat longer burn times. I think Craig's point about cats working best for 24/7 burners is true to. Loading in a already warm stove allows you to re-engage the cat quite quickly, in a cold stove it takes a while to get warm enough to engage.Ken45 said:Webmaster said:There is something to be said about not having to load the moment you go to bed and again the instant you wake up.
I believe you are saying that cats burn longer so you don't have to jump out of bed and reload them?
But from what I think I understand from reading here, you are not supposed to add additional fuel to a cat until it has burned way down? Doesn't that make it harder to load it up at bed time? Doesn't that pretty much tie your schedule to the stoves burn schedule?
I'm new here so please forgive me if I'm all confused!
Ken
Mike, sounds like you're seeing the secondary technology improving to the point where it is almost as good as the cats in being self sustaining at very low burn rates?with a cat stove or a newer type non-cat the primary air can be dialed back to where just enough air hits the wood to maintain and the “secondaries “ (the cat , or the reburn process of the non-cat covers the heating “load” needed to warm the structure. taking over from the “primary fire” allowing long burn times
Pine Knot said:The long burn times of my cat stove provide welcome flexiability as to when to load at night and reload again in the morning. It just takes some of the pressure off of my early morning routine.
Pine Knot said:New last fall, and a big improvement over what I had, a Drolet Adorondack. The Dutchwest is cleaner, puts out steady heat, and requires less tending to. The Drolet was a noncat and the secondary burn worked well, but it had other issues, short burns, ash removal the main short comings.
