I bought a used Jotul F600 about a year ago. I did some research and specifically looked for one of these because it was touted as one of the biggest wood stoves on the market and had good reviews, plus Jotul just has a great reputation. After a year of use, I am disappointed:
It seems to light OK and i has decent air flow. There is a longer section of horizontal exhaust that was not there before with the Garrison (the Jotul exhaust is higher up so I had to set it on the floor in front of the hearth instead of on it). But I followed the specs for the minimum slope and it's only a couple feet.
I've read that you should really heat up the stove every once in a while, get it into the high side of the burn zone, and it will burn off some of the creosote in your exhaust/chimney. I used to do this with my old stove but I can't with this one. I can barely get it over 300 into the burn zone at all no matter what I do.
I occasionally can see the secondary burn tubes doing their thing, but not very often. somtimes it does look like it is burning the air coming from them but other times it looks more like the flames are being pushed *around* the incoming secondary air, and not actually burning. Regardless, I would think that even without the secondary burn, I should be able to get this stove up to 500 degrees without too much trouble.
Does anyone have any advice on what could be going wrong here? or did i just buy the wrong stove?
Thanks.
- I can barely get it over the 300 degree mark on the thermometer into the burn zone
- it seems to EAT wood. The specs say it burns for 6 hours or something like that. that is a joke. I'll fill it up, close down the air, and if it burns for a couple hours before needing wood again, that's about the best it will do. I have to wake up 2 or 3 times a night to keep it going.
Thanks.
