What size Tank for Gas Freestanding Stove
Dataman
1,345
Newport, Wa
In the Future I am thinking of Upgrading our Pellet Stove (Harmon XXV From 2018) to Gas Freestanding Stove. Want to do it when we do siding on house and get rid of the two 40 gallon tanks for big tank to feed Gas Cooktop and Freestanding Stove. What size tank to last the Winter in NE Wa State. We see -20 every once in a while. Main source of heat is Cold Weather Heat Pump (Midia G3 Evox good for -20f). Right now no problem with pellets. But I am 67 and in the future I bet it will be difficult to lift 40 lb bags.
Another option is just get 20lb bag if it's difficult.
1st Season of Using Cold Weather Heat Pump is this year. Hopefully cut pellet use by 1/3 (We use 3 Tons normally).
Hoping for 500 gallon tank.
We have 8" Chimney and hope to get the same size BTU as Pellet Stove. Harmon is lacking at -20f. Has hard time keeping up. Burning 2 bags and it keeps house at 70f at most. Typically we have 74f inside hallway.
Just thinking ahead and planning for the Future!
  • [Hearth.com] What size Tank for Gas Freestanding Stove
What is your annual consumption of pellets?
Long ago I had a heat & glo gas stove for my then 1800 sq-ft house, I would use it exclusively for heat in the fall and would use about a 100lb tank every three weeks (I had two on a combiner). There’s about 24 gallons in each 100lb, in the winter I bet that consumption would have doubled if it could have kept up.
So in my case 6 x 2 x 24 = 288 gallons probably would have been more then enough… the bigger the better in my opinion, my issue lately has been finding someone who wants to loan that big of a tank for 2 appliances (most want to sign you up for autofill).
re pellets - what I do is pour the 40lb bag into two 5 gallon buckets. It's easier for me to carry down the basement stairs. Also easier to pour into the hopper. If you want to go deluxe you can buy the lids too. You only need to carry one at a time, as 1/2 a bag would last for at least 8 hours. Personally I would not rely on heat pumps only for sure. They freeze up and have to thaw themselves out. Plus if you have no power they are useless. A wide range of options is best. I have 2 heat pumps, pellet stove, and many convect heaters. I burn about 1 bag per day on average at it's in the finished basement, and hard to circulate the heat upstairs.
Reactions: Turbo89
No basement Pellet Stove. Just upstairs on back porch. Just thinking ahead. Thanks
Reactions: Whitenuckler
3 Tons without Heat Pump in Cold Weather. I hope for 2 tons this next Season.
I think a thoughtful person could have a hopper built or buy one that allows for easy filling of pail, and pay for delivery into the hopper. A vacuum system could be built as well.
When it comes to cost comparisons I like this site. https://www.efficiencymaine.com/at-home/heating-cost-comparison/
I’m all for planning ahead. And I’d just get the biggest tank I could afford. 500 gallons would be my smallest choice.
My quick googling shows a bag of pellets is about equivalent to 4 gallons of propane. So your 100 bags is about 400 gallons. Someone should check my math. 500 gallon tank is be ok with.
No Pellet Delivery here in Bulk. They only deliver wrapped 1 Tons packages. Last year it was 90 bucks. Won't deliver in SNOW. This year since we have 2 tons sitting will only order if we run low. Typically use 3 tons. Hopefully Heat Pump can pickup the slack (One that works down to -20f). If not we have Pickups. Use Tractor to get from PU to house. Sorry about pic upside down. Even when I turn it it still shows upside down. Strange.
This Winter Season will be interesting to see how much Heat Pump does vs Pellet Stove. Unknown, old Heat Pump we quit using at 30f. This one I will run until -10f if Numbers Show it's not too much of Elec Hog. Kw here is .006 so it's pretty cheap.
500gal tank here for my home runs furnace and hot water heater. run a Englander nc30 wood stove. that does most of the heating all winter , but like you we have the dips to -30 area, and runs that stay below zero for a week or more at a crack. I do not have a separate rental fee on tank, but I do a 500 gal prebuy in June so I have a fixed price all year. If price per gal. goes down below my fix cost I get the lower price in Jan / feb. when they top it off. Note tanks are only filled to 80% so that is 400 gallons. I don't consume much more than 600 gal all year.
Reactions: Dataman
Thanks Everyone. I will shoot for 500g when the time comes. Now to find Free Standing Stove (Gas) that is as Many BTU as Harmon XXV. It's undersized at -20f for the house. Can't keep it at 74f. Slips to 70f.
Can you upgrade the insulation or air sealing so you use less energy to heat?
Don't think so. House built with 18" Walls and tons of Insulation. Overbuilt by prepper from Alaska. Stays Cool inside. 84f outside. House is 73f and AC will kick in at 74f. Went down to 48f this AM and house went down to 71f.
