Good morning - this will be my second season owning a Yukon furnace. Do you have a certain outdoor temp guideline before you will start using your furnace?
As a former Yukon owner, you have my sympathy's, hopefully it works out better for you than it did me.
As for the temp...I wait until its in the low 50s (or less) or so to do a cold start (chimney draft)and the house is down to the upper 60's...much less than that and there will be much squawking! If it is just a short term cold snap I will fire up the wood stove in the living room fireplace, that takes the chill off the house pretty well, but once the whole house cools down, it doesn't work as well being a "room heater" and all...
This should give you a good idea of when I light my first fire. For me it's based on nighttime outside temp related to inside house temp. If the house is into the 60's and the temps outside are going to drop much below 50 or so, I will probably light a fire.
- Morning, Afternoon and Night corresponds to the loading weight.
- Hi and Low corresponds to the daily high and low temp of the day, with CALC HDD is the calculated HDD's based on the low and high.
- LP Away is how many minutes the LP furnace ran, based on the minute timer I have on my LP furnace when it calls for heat.
You'll see below the LP furnace ran a total of 514 minutes before I decided to light my first fire of the year on October 17th. If I had the basement ready, I probably would have lit one a few days earlier than I did. The abnormally warm fall we had kind of lulled me to sleep.
This data is amazing & helpful. What method do you use to weigh your wood?
Just so everybody is clear, the Kuuma and the HC still make the most heat early on in the load...similar to your Caddy...they don't do "low n slow" like a cat stove will...they just keep the fire maximized (burning clean) for the "load" that the computer is seeing (via the controller:Kuuma, or the t-stat:HC)If I had a Kuuma or HC that provided consistent heat across the whole burn I probably could burn when temps are a little higher. I have a Caddy and you tend to get a lot of heat at the beginning of a load.
Based off of your experience with multiple furnaces, you don't think the Kuuma does a better job of creating even heat through out the burn vs the T1 you had ? I'd say the T1 and Caddy are very similar on how they burn.Just so everybody is clear, the Kuuma and the HC still make the most heat early on in the load...similar to your Caddy...they don't do "low n slow" like a cat stove will...they just keep the fire maximized (burning clean) for the "load" that the computer is seeing (via the controller:Kuuma, or the t-stat:HC)
A little better, yeah...but still certainly "front loaded"...look at one of @JRHAWK9 s temp trend charts, you'll see what I mean...Based off of your experience with multiple furnaces, you don't think the Kuuma does a better job of creating even heat through out the burn vs the T1 you had ? I'd say the T1 and Caddy are very similar on how they burn.
I built a fire at 62 degrees lol. Did a small break-in fire. The house actually was comfortable due to the fan shutting off and the fire dropping to a low burn.
I saw the reply in my email and was wondering why you needed to do a break-in fire on your old unit. Thought you may just call the first fire of the year that. I then accessed the thread a couple hours later and saw the photo. Makes much more sense now! Congrats!
Got you a new toy I see. What did you end up getting ?I built a fire at 62 degrees lol. Did a small break-in fire. The house actually was comfortable due to the fan shutting off and the fire dropping to a low burn.
Laynes --looks like a nice set up for house heating and hot water. So its boring in time...lol clancey
As soon as the girlfriend says she’s cold. So this year my first burn was around the end of SeptemberGood morning - this will be my second season owning a Yukon furnace. Do you have a certain outdoor temp guideline before you will start using your furnace?
It gets worse with age...and being preggo!Women have -BAD- HVAC systems!
Yes , I often run the heat and ac in the same week. Welcome to Ohio where the weather changes back and foundIf I used that as a gauge I'd be going from heat to AC back to heat back to AC.....all within a few hours! LOL The house can be 70° and she'll say she is cold one minute to then being too warm an hour later......when the house temp never moves.
