Two boilers, pellet and oil; installing pellet now. Currently, circulating pumps and thermostats fed by oil boiler power. Will be adding two boiler pumps. How should I wire it up? There's a switch now near the oil boiler that turns everything off. There's an emergency switch at the top of the stairs that turns everything off. The pellet boiler will be on its own circuit.
The oil boiler breaker will have to be on whenever the zone circs are running, so that breaker will have to be on, even if I want to take that boiler out of service, if the pellet boiler is still running. I guess I could just unplug the burner or wire up the local switch for that instead of taking everything off line. Each of the circs currently have a switch as well.
I guess I'll run another circuit up to the top of the stairs and add another switch for the pellet boiler. The zone circ pumps will still have power when only the pellet switch is thrown. Maybe a double pole double throw switch for both?
I'm still plumbing but my mind wanders.
What do you think?
What do you think?
