Anybody ever use this stuff,sounds bogus to me, but, never used anything like it. Don't get more than a quart of creosote in a years burning with the BK.And that's only in the last eight feet of chimney to the cap.
We've used the spray since we started burning, our stove (Lopi Liberty) was put in April and I was cutting a chit load of Cherry mother nature knocked down so our wood was coming in around 25 -28 percent M/C. I resplit most of the Cherry and after being inside for a good week, it was 22 percent M/C.Anybody ever use this stuff,sounds bogus to me, but, never used anything like it. Don't get more than a quart of creosote in a years burning with the BK.And that's only in the last eight feet of chimney to the cap.
Yeah I am sure different projects have different effectiveness. I don't know enough about them all to know which is besti used the spray and it did nothing for me. i now use the csl log the last fire of the year. it works way better. burn it in may brush the chimney in october and thats it. i have a very thin layer of shiny. and it dries it up so if it doesn't fall off on it's own when i brush it it comes off
Sounds good however in the heaviest burning season ,at seasons end the most I ever got was a quart of what appears to be black fine sand. The liner stays shiny, never any build up, however my wood is never over 18% when burned ,all situations are unique.My chimney won't get cleaned till April,and for it's coating then dust only. My BK is a clean burner.It does help to make glazed creosote easier to clean. But it shouldn't be used with a cat and you shouldn't use any of the salt based stuff with a stainless liner or chimney. And for the record I get atleast twice the creosote with the bk princess than I did with the regency 3100. And most bk chimneys I work on are fairly dirty. They are not the cleanest burners.
Mine is always sub 20% usually under 18. It does elbow into a chimney though not straight up which I am sure hurts be some. But I work on 2 princess inserts that have similar buildup. I would say most BK's I clean average about a gallon of pretty dry creosote only one typically has glaze and that is going into an exterior clay liner chimney so not the stoves fault.Sounds good however in the heaviest burning season ,at seasons end the most I ever got was a quart of what appears to be black fine sand. The liner stays shiny, never any build up, however my wood is never over 18% when burned ,all situations are unique.My chimney won't get cleaned till April,and for it's coating then dust only. My BK is a clean burner.
I burned some wet wood by mistake and glazed up my stove and chimney over a half a day this a few years ago. The wood was far wetter than I’d thought and when I checked on it was nearly out. Glazed the stove bad. It was horrible. I bought some Cre-Away powder made by Saver Systems. Says in the bottle not to use with Catalytic stoves and this stove was not a cat or tube stove. However they make an ACS...Anti-Creosote Spray that can supposedly be used with catalytic stoves. Are you familiar with this and does it work?It does help to make glazed creosote easier to clean. But it shouldn't be used with a cat and you shouldn't use any of the salt based stuff with a stainless liner or chimney. And for the record I get atleast twice the creosote with the bk princess than I did with the regency 3100. And most bk chimneys I work on are fairly dirty. They are not the cleanest burners.
Bk makes great stoves without a doubt. They have some very strong points and some where they are weaker. For some situations they are without a doubt the best stove. Others not so much. You need to figure out what it is you need and what your most important performance characteristics are. From there you can narrow down your search. We sell regency stoves and overall they perform well and are pretty durable. As are lopi quadrafire pacific energy and many others.I burned some wet wood by mistake and glazed up my stove and chimney over a half a day this a few years ago. The wood was far wetter than I’d thought and when I checked on it was nearly out. Glazed the stove bad. It was horrible. I bought some Cre-Away powder made by Saver Systems. Says in the bottle not to use with Catalytic stoves and this stove was not a cat or tube stove. However they make an ACS...Anti-Creosote Spray that can supposedly be used with catalytic stoves. Are you familiar with this and does it work?
Also, several years of research brought me to the same conclusion that I wasn’t liking what I was seeing with BK and chimneys getting creosote. Of course, every situation is different and it’s hard to know how wet the wood being burned is unless some notes it, but for the claims of being so clean burning I was skeptical. Not saying they are that way by any means. Interesting to note about the Regency. They never really were on my radar until recently when these newer 2020 stoves came out. They seem well built like Lopi stoves.
Is that after burning a full season,if so a gallon after 6 months burning is liveable.Mine is always sub 20% usually under 18. It does elbow into a chimney though not straight up which I am sure hurts be some. But I work on 2 princess inserts that have similar buildup. I would say most BK's I clean average about a gallon of pretty dry creosote only one typically has glaze and that is going into an exterior clay liner chimney so not the stoves fault.
My regency on the other hand was just a handful of grey powder.
What I see on them isn't by any means an extreme ammout of buildup or anything. Just more than I was used to.
Yeah it absolutely is liveable. Just more than I see from most other modern stoves. But not anything extremeIs that after burning a full season,if so a gallon after 6 months burning is liveable.
A boiler that we typically get about 20 gals out of. 5 gals is not that uncommonWhat’s the worst system you clean every year?
As a kid our giant smoke dragon in the basement was cleaned a couple times a season and always made at least a 5 gallon buckets worth on a 2 story masonry chimney.
What in your opinion is the absolutely cleanest burning stove, in your opinion.Yeah it absolutely is liveable. Just more than I see from most other modern stoves. But not anything extreme
I have no clue. Especially with the new stuff on the market. And the testing numbers are not real world situations so they don't help much. I can tell you on average good tube stoves burnt correctly put just about the least amount of deposits in the chimney. But that doesn't mean their emissions are the cleanestWhat in your opinion is the absolutely cleanest burning stove, in your opinion.
What other stoves have you run full time out of curiosity?What in your opinion is the absolutely cleanest burning stove, in your opinion.
Buck,= garbage,What other stoves have you run full time out of curiosity?
Morso first stove,decent to a point ate wood like crazy ,not enough heat output,Buck their biggest ,an absolute piece of you know what ,lost my rear end and sold it at a great loss in one month.Then two Quadrafires,first one sides cracked and was replaced under warranty,second one sides cracked from heat also ,got a cash credit,then got a BK,King pedastal,it made a believer out of me,sold it and got another King ,this one the Parlor liked its looks more than the pedastal,no complaints on either love BK,probably will never switch.What other stoves have you run full time out of curiosity?
I never liked the buck cat stoves but their noncats seemed to be decent from what I have seen.Buck,= garbage,
Yeah I never took issue with their build quality at all. And have never heard many complaints about their function. I just don't like the way they designed the internals for their cat stoves. They are not easy to service at all.Which model Buck did you not like? How old?
Our family owned an old one for years that my uncle copied and made his own changes to the design. Still, they were both good stoves, great for heat, but not good by today’s standards.
I’ve looked at the build quality of newer Buck stoves as recent as 2019 stoves. As far as being heavily built and quality of build they are as impressive to me as the Drolet stoves I’ve looked at that so many people rave about, same heavy construction as the Osborn stoves I’ve looked at, though maybe not as easy on the eyes, and as heavy made as the Lopi Liberty that I own...at least looking from and comparing the outside of the two stoves even though there are differences. All these brands have 5/16” top plates, some of the heaviest in the industry. Regency may rank with them as well as far as heavy construction and top plate thickness. Love them or hate them, Buck’s name has stood the test of time...at least as long as some of these others, and maybe longer than some. Are they the best? Not by a long shot, neither are they the worst. Speaking strictly from a build perspective. I will say that in the last Bucks EPA numbers were not impressive by any means compared to these other brands, but they’ve had to come around some in order to meet new 2020 regulations. A few models have passed, which puts them as another option for people.
