Which usually wears out first, the clutch or the drum?
I bought a Homelite XL (UT-10655) 16" off CraigsList for $35. The guy said it needed some help. It starts and runs. I cleaned it up, filed the bar a tad, flipped it, chain looks good and sharp, added bar oil, replaced the pull rope and fired it up and tested, adjusted the idle. It does well on the small stuff (4" or so) but the bigger oak (6" +) it'll keep revving but the chain will stop if I put a lot of pressure on it. So I took it apart today, took off the clutch drum to check out the clutch. The clutch and drum have some gunk on them, maybe thickened grease or something, not entirely sure. Will clean that out and see how it does. Maybe get a new drum at some point, hence my question...do the drums wear out first and the clutches keep going or ? How does one tell exactly? Do the clutches have anything on the contact surface like brake material, or is it metal to metal contact?
I've attached a photo of the clutch (gunk visible top side) and the drum (same).
Any info appreciated.
Also, since I don't have the special tool to remove the clutch, and I tried a punch and peen to see if I could relatively gently knock it loose, what is the best way to remove the clutch (and do I really have to worry about a needle rollers of the clutch bearing??).
More pics / details here: http://www.sierranature.com/temp/homelite.html
Thanks for any info/help!
