My gas insert is about 2 years old. There is an ashy white powder building up inside the unit on the walls (there are fake brick panels on the back and side walls) and also on the top (inside). Is this due to some contaminant in my gas supply, or perhaps a sign of air leaking into the unit around the seal on the front of the unit ?
Thanks. I appreciate any input you have...
) should remove it. if not present in this area but is in the other regions you mentioned , check flue if applicable , or log position , flame should not directly contact logs , at least not heavily , this impingement causes a rich burn which can leave either a whitish or sooty residue , depending on amount of impingement or log material. hope this helps. by the way if this unit is vent free , i would avoid using it until the culprit is found and fixed (not due to danger as vent free's are extremely safe , but they can have a tendancy to cause yellowing in drapes, white paint etc, if they are burning rich)
