Oddly enough, I thought I could find the answer fairly easily with all of the great FAQ's on here... but it hasn't been the case. I have learned quite a bit about the stove though! I have narrowed it down to what I think may be the issue.... but I'll lay out the testing first.
Issue- Auger (even on high) spins super super slow. I marked it with a pen, and it takes about 2min for it to turn just 1/8 of a turn. (If that)
The pressure switch has continuity.
The high limit switch has continuity.
The low limit switch does not have continuity. (Stove wasn't being used, so this makes sense)
The motor when connected directly to AC runs super fast.
The gear box is fine, the auger mount spins fine.
The motor when connected to the blower power works fine and feeds pellets no problem. It just feeds them too fast on high!!
The potentiometers both register variable values when connected to one side and the middle tab. (The other tab and middle do not register values on either pot)
The auger light does flash like it is working right, although it is a quick flash even on high. (Maybe normal)
I used the wiring diagram on page 12 to verify all my connections.
http://www.hearthtools.com/parts/whitfield_wire_diagrams.pdf
So, after checking all that above and everything functioning the only thing I have left is the amount of voltage being applied. When the motor does get voltage, the meter doesn't get up to 120v. And it only gets it for a quick mili-second.
My thought is the auger power timer (pulser or whatever it is called) is going bad a quickly shuts off the power. Anyone ever had this issue?
Thank you very much, this forum has a wealth of information!
