Who knows pipe insulation?
goosegunner
1,469
WI
I bought some fiberglass pipe insulation off craigslist. It is the Owens corning 1-1/2" thick with the white cover on the outside. I got about 50' of 1-1/2" and 50' of 2" size.
My piping is 1-1/2" copper and 1-1/4" copper the insulation is big and has a air space. Should I cut it down to have it fit the pipe better? I thought I could use a table saw to cut a strip out of it length wise to make it fit better.
gg
Its sounds like you got the insulation that is for Iron Pipe size. As Frozen Canuck says, it would be better to use a knife. It will still not conform to the pipe shell properly. It will end up egg shaped and will look oval when you do up the but strap. It still better than no insulation but will leave some aesthetic issues. It is always easier to shell out under sized insulation than to cut down oversized. The smaller diameter of the pipe makes it difficult to follow the arch.
Time to stick your tongue out to the left and do the best you can. %-P
Good luck.
Yes, it is iron pipe size. I figured that I could make it work some how so I bought it. I will use the 2" in the area behind my tank it will never be seen. The 1-1/2" seems ok on the 1-1/2 copper I will use that in the boiler room.
So does the air space even matter if I didn't cut to fit snug?
gg
Wow I just looked it up on line that stuff is pretty pricey, about $17 - $19 a 3' section. I paid $50 for all of it, almost two full boxes. It is R7.5. I actually have 54' of one and 48 ' of the other.
(broken link removed to http://www.zorotools.com/g/00065925/k-G2463081?utm_source=google) shopping&utm_medium=cpc&utm_campaign=Google+Shopping+Feed&kw;={keyword}&gclid=CPin1YPu3qsCFdAEQAodKCgl_A
gg
Sounds like a good $$$ deal, think of it this way you have been well paid to take your time
You might want to try wraping a thin layer of normal fiberglass insul around the pipe first (to increase the OD) then apply what you bought
Worth a try IMO
Worth a try IMO
Good idea
gg
Worth a try IMO
+2
Started covering the pipe in tank area today. Thanks for the idea to add insulation. I just cut some strips of fiberglass batts, pulled them apart and put the inside the piece before I put it on the pipe.
gg
  • [Hearth.com] Who knows pipe insulation?
I wonder if a person could make their own pipe insulation by wrapping and taping sized and cut lengths of standard fiberglass insulation around pipes. Maybe foil backed insulation taped lengthwise with the foil backed tape you use for sealing heat ducts. Just a thought. Anyone see an issue? It would probably be a lot cheaper than the prices Goosegunner mentioned above, although more work.
Mike
Mike
You definitly could. Lot of work though. I insulated all the piping for a school my brother and I plumbed. Yuk.
