Im looking for some advice on diagnosing a snowblower engine, a briggs thats on an ariens snowblower. Im very good with most engines, but small engines get me sometimes. It has lots of hours although its only 6 yrs old, probably close to 200 i bet. The engine smokes on startup, but you cannot see any smoke when its running and otherwise runs ok. However, it is burning oil. I may need to add 1-2 ounces every 3 hrs of use. This tells me its probably oil getting past the piston rings. It may be worn to the point of a rebuild or new engine. Does anyone have some thoughts on this? Stuck rings? Valve clearance? im at the point where if i cant add anything that may help the symptoms, i may buy a new engine. I did check the valves last year and they seemed ok.
Thanks guys
Thanks guys
