Why I Use Pellets
johneh
6,298
Eastern Ontario
Here is the reason I heat with pellets and wood
I could not afford this It's hard to make ends meet now .
The cost of NG in Ontario is going up 40%
(broken link removed)
I heard about that on the radio on my way into work today. Glad I'm no longer reliant on big energy (well, other than hydro one to run the stove and fans ;) )
Everybody converts then they jack the prices, then all the excuses like cold winter, shortages, bla bla bla but the price will never come back down, so corrupt.
I save approximately $1200 per year over heating with oil.
Reactions: undr
I will save that much or more...just need to plan for next winter.
I like to be warm and can't afford fuel oil
Enbridge spokesman Chris Meyer said this is all because storage pools of cheap gas have been depleted by this year’s extremely cold winter weather.
So they are going to fill them with more expensive gas?
Wow! No wonder I'm getting so many Garn calls from Ontario.
If you can, look into Bio mass fuels.
We use hazelnut shells and heat a 2400 ft house for under $100 a season.
Yeah the numbers are right, under $100 a season.
Not sure what you have up there, but I would be looking at any bio mass fuel such as nut shells etc that will feed through the stove.
Many "pits" work too.
Fruit pits, any biomass with sugars present (IE: corn) and some nut shells are proving to be quite acidic. Users are finding this out, to their dismay, after about 3-4 years of use.
Do some research on alternate "pellets" before you take the plunge in that direction.
I thought they called them "Filberts" in Oregon! :)
Dave
its been 12% colder in Degree Days and a record supply of Nat. Gas was in surplus .. and supply as well . There trying to **** and Pillage all consumers and line a lot of pockets will cash....Same old corporate story
My next move is to burn politicians & greedy CEO's, etc..,. I burn sludge at work so I should be able to burn BS at home. Stay warm & thirsty my friends.
So far this year by burning pellets I've saved approximately $2400 over burning propane using $3.00 per gallon as an averaged propane price.
The last price I heard on propane was $1.09 a Litre. So times that by 3.78=$4.12 an American gallon (minus whatever the current exchange rate is.) would be about $3.71. I am pretty certain it has even gone up from there.
Seriously Ontario people those clowns in Toronto have to go. Nobody voted for Wynne, she was inherited from McSquinty and his croonies!
And I have never heard of a bag of pellets leaking and blowing up a house.
Reactions: heat seeker
Or a multi story building because the supply line got old.
I've got a 500 gallon tank that I filed when the price was $2.09. By my calculation I would have burned roughly 1100 gallons of propane. So I would have had to buy another 600 gallons at the $4.00 price. So I just averaged my savings based on $3.
Why would you think you are safe with pellets? For now we are. Give it time.
When I first bought a pellet stove, I paid $139/ton. Then it went to $169/ton. When oil spiked, the price went through the roof. I'm seeing a lot more pellet companies now, than I did 20 years ago.
This winter may very well increase next year's price, but big box stores seem to keep prices in check.
Wen
Went through 2 winters out here that I burned very few pellets,propane was very cheap.Neighbors laughed at my stove.Now those folks installed wood and pellet stoves.
Wen
Same thing here. Neighbor got a used stove and calculated pay off to be one month and was warmer. Propain still above $3. Now he is looking at larger unit for his auto shop. If they dont stop pumping Bakken crude south, propane may not go very low this year an I don't know how farmers are going to negate the cost. Lower income families can't afford to heat with propain or convert to what? Hot air exchangers converting BS from politicians?
My only concern what if they started jacking prices of pellets up 40%, since everything else is going up!
