The glass cracked on my 1979 Resolute III. I had new fireproof glass cut, but now I can't find the coated wire gaskets that go between the double pane glass. I use the stove to heat my home and it's getting cold. I have tired to find a a small gauge fireproof gasket, but can't find anything small enough. I believe I need a 7/16 " gasket. Also, the original is a wire covered in a fireproof fabric. The wire enables the gasket to hold it's shape in order to put the glass in the door properly. I love this stove and can't believe this small, seemingly easy to replace part, could cause the stove to be unusable. Any suggestions? Fireproof calk???
![[Hearth.com] Window Gasket replacement Vermont Casting Resolute III [Hearth.com] Window Gasket replacement Vermont Casting Resolute III](https://www.hearth.com/talk/data/attachments/284/284312-a4dcb47c339d6009386823d3748e0cf9.jpg?hash=ODLJouF1Kz)
