Yesterday I picked up a Avalon Pendelton stove for my sister-in-law. The stove deal came complete with the chimney liner. My plan we to get the stove for my SIL and use the liner on my house. I have a freestanding stove at the front of the house and a fireplace with an insert that was done all wrong. The previous owner put the stove in the insert after opening the damper hoping the stove would draw. They were wrong.
Yesterday I got to the seller’s house and he had removed the surround from around the insert. I removed the screws that held the liner to the stove and climbed up on the roof to remove the pipe. I found that the installers had cut the terra cotta chimney flush with the brick and put the liner through and cemented around it. It did have a stainless cap on it. I had the seller come up in the roof with me to see what he had. We could see terra cotta above every other chimney in the neighborhood so the installers had to have cut it back. I left with no liner.
He is replacing the wood burner with a gas insert. He said he would save the liner if the gas insert installers replace the existing liner. I have very little hope that they will.
Can you use wood liners with a gas insert? I thought I read somewhere that you shouldn’t. Any insight on whether the gas insert installers will suggest replacing the wood liner?
Thanks,
Bob
Thanks,
Bob
