Working on trying to solve my heating issue in the foreclosure I purchased last year. Here is what I have in my 2 story (with a basement), 3000 Sq ft, post and beam construction home.
Prefab chimney with two flues. One goes to the main floor to a zero clearance firebox (currently has a gas insert....the gas tank was taken once it changed hands...was a rental tank). Second flue runs to my basement where it is hooked up to my forced air oil fired furnace and also the oil fired water heater (see picture below).
Yes, oil prices are cheap but my goal is to heat the house with wood. I've got plenty of wood on my property. My goal is to install an add on wood burning furnace in the basement which will utilize the flue. Power vent the oil furnace and water heater directly outside from the basement. Put a pellet stove on the main floor that vents directly outside (so the flue running to the main floor of my house will not be used). The pellet stove would be for late fall and early spring when firing up the wood stove is too much.
Couple questions that I'm trying to figure out.
1) I'm not 100% sure what type of flue I have that is hooked up to my oil furnace/water heater. Do I need to replace the entire flue with Class A pipe or can I install an insulated liner down it and hook that up to the wood stove?
2) Can I power vent the oil furnace and water heater in one vent? Does anyone have an idea of what something like this should cost when hiring someone to do?
Please see the picture below for my current oil furnace and water heater.
I'm trying to do all the research I can on wood furnaces. This stove is local to me and I went and looked at it today. Two years old. Thoughts?
(broken link removed to http://baltimore.craigslist.org/grd/5429272483.html)
Any insight on this would be great. Willing to pay some money to do this right....but trying to keep it reasonable as well.
Thanks!
Thanks!
![[Hearth.com] Wood Furnace in prefabricated chimney [Hearth.com] Wood Furnace in prefabricated chimney](https://www.hearth.com/talk/data/attachments/176/176222-f95d05957df5ab9e6ed13d51eb980481.jpg?hash=upErki0SEo)
![[Hearth.com] Wood Furnace in prefabricated chimney [Hearth.com] Wood Furnace in prefabricated chimney](https://www.hearth.com/talk/data/attachments/176/176223-4bb716f3b7c8070a67a4453edee32c6c.jpg?hash=BpT9IIASHk)
![[Hearth.com] Wood Furnace in prefabricated chimney [Hearth.com] Wood Furnace in prefabricated chimney](https://www.hearth.com/talk/data/attachments/176/176224-efc85a501ebde2dc8d3268f4a84d4850.jpg?hash=EqGQnHOQST)
