We had a TARM SP140 for the first 11 years after we moved here, it rusted through at 19 years of age and was replaced in 2012 with a Wood Gun E140. We burn an average of about 20 standard cords per year. I like the WG a lot so far but there are a couple of problems I am having. One is with the fan bearing, it began to sound loud intermittently in December so I bought a spare. I tried to replace it on one of the few above-freezing days we had in January when I could shut the boiler down for a while. I stripped the threads on an old puller trying to get the fan off the shaft, then I bought a new 4 ton rated puller and could not budge it with that. I put it back together and called AHS and they recommended using a propane torch to heat the fan hub and get it to expand and pop off. If we ever have another warm day I will try this. I found a tutorial video on YouTube but the person making that video had the same problem I did. If anyone out there has actually replaced the bearing successfully and has any tips on how to do it I would be very grateful. The other thing I am wondering about is the load door gasket. It is silicone and is still in excellent shape after 2-1/2 years and 50 cords of wood but eventually it will wear out. To replace it as per the manual requires 2 days for the silicone to cure. We do not have any backup heat at this time so in the winter that would not be very handy. Is it possible to use a fiberglass rope gasket such as the lower doors have? Thank you very much for any advice. I found this forum very helpful when we were deciding what to buy to replace the TARM. I didn't join at the time but I read a number of threads.
Zach
Zach
![[Hearth.com] Wood Gun fan bearing and door gasket questions [Hearth.com] Wood Gun fan bearing and door gasket questions](https://www.hearth.com/talk/data/attachments/153/153377-d0859763faf75d877378ed4e58aa8385.jpg?hash=F0gWuY8kON)
