Wood ID
There are a few Very Large Elms (3+ ft. Dia.) around the corner from me. So we do have a few old survivors here. I also spotted an old chestnut tree in a neighbors yard. It's the only one i've seen around here.
I tried to find a pic of the 278 year old "mother" elm but could not locate anything. I thought i did see a pic many years ago when i got my princeton elm but not 100% sure?
This is the bark on my Princeton Elm. Out front.
From the main trunk and up into the branching.
As u can see the bark varies quite a bit as you go up the tree. (It's roughly a 20 year old tree)
  • [Hearth.com] Wood ID
Pics of these when you have time? American elm here do not get that big. Both Siberian and reds do.
Love the chestnuts. Both for their structural beauty and the Chinese chestnuts are the edible ones with the spiny hull, nuts are inside. Horse chestnuts are extremely bitter.
Reactions: bigealta
Yep, those pics seem to bear a resemblance to the pics of the firewood you posted on page 1.
The only thing that doesn't seem right is the long, hot burn you say it has. American Elm, which I think is what a Princeton Elm basically is, I've seen BTU ratings of 19.5. That's about like Black Cherry which I've burned a good bit of. It's decent, but a notch or more below the Oaks, Hickories etc. But maybe you mixed in some of the Oak with those loads that were burning so well..
Reactions: all night moe
so i just did some reading on btu values/ratings. The points that were interesting is that the ratings can vary by quite a bit by many factors including growth rate, general location (growing season time), location (deep woods to open field) Nutrients available, Sun exposure. Ground composition, etc.
So a 50 year old 12" tree growing in the deep woods in canada with very tight growth rings, would have quite a different rating than the same variety 12" tree grown in an open field in florida which might be only 10 years old with fast grown wide growth rings, and it's much less dense wood.
It seems these factors can help explain why we see different ratings on different charts.
Very good point.
Kudos to your research on all of this.
I'm sure that's true to an extent. Some of the pics the wood in question had both narrow and wide rings. But your White Oak pics had some pretty tight growth rings, for sure.
[Hearth.com] Wood ID [Hearth.com] Wood ID
Those pics from Dieselhead do show his white oak yes. Those growth rings do seem pretty consistent and tight. Not sure what your point is?
I was just saying that an Elm grown here could have a different btu rating for this specific tree vs the general ratings on other elms.
And i'm not even sure it is an elm? or field elm. It's just the closest thing i've found based on end grain which the experts say is the most definitive way to ID a tree.
Oops, not your Oak, my bad. ;em If your Elm is burning that long and hot, that's great. The heavy weight you attribute to it could very well indicate that growing conditions were favorable for a higher BTU output than normally expected, as you pointed out.
My experience burning American Elm is quite limited. I get a lot of Red (Slippery) Elm here, which seems to burn and coal well.
This entire wood end-grain ID angle is an interesting approach which I've not come across much until now, thanks for the heads-up on that. 👍
Reactions: bigealta
For All Night Moe:
Here are the pics from the Large Elms near me. One on Left (#869) is 4+Ft. Dia. One on Right is 3+ Ft Dia.
And here is the Old Chestnut. Just hanging in there.
Red elms. Bark says no for American elm, and Siberian has a different crown structure.
Edit/add on: look like the smaller ones came from that big mama.
That chestnut is an old girl. Looks to have been possibly topped before.
For those still reading this ID thread here is more info on end grains. The ring of circles or dots you see in grains is the early wood formation. The darker (in this sample), more solid areas, are the later growing wood. The cycle repeats every year.
The Red Elms here don't have the deep bark ridges that the OP's latest pics show, it's more flaky/scaly in appearance. That said, the biggest Red bark I've seen here was on a 19" tree, and these are woods trees. Maybe a bigger Red out in the open would have the deeper bark ridges, IDK.
Interesting AI response. Seems like some of the OP's pics may show some of this...nothing very distinctive, though:
Searching
"The primary difference between American elm and slippery elm bark is that the American elm bark has alternating light and dark layers when cut in cross-section, while Slippery elm bark has uniformly dark layers."
Searching
The American I have climbed and removed all had the smooth scaly bark you described above. Some killed of by the dutch elm disease, with the bark felling off in "sheets."
I've taken Siberian down too, and they have deeper ridged bark similar to the reds. Never taken a red. Just noted their unique beauty. I believe the Vermont Castings Elm stoves have that red elm on their decorative doors.
We've all noted how hard splitting American elm is....it's a brute. Siberian is much easier but a very soft wood. Not worth the effort for BTU per pound. Again, never touched the reds.
There is an awesome specimen of a red 10 miles from me. It's on a state highway. One of these days, if I'm not in a rush, I'll pull over and see what my app says about it. It's not the most accurate all the time though.
Reactions: bigealta
Red Elm isn't real hard to split, the straight stuff anyway, but I usually let the power splitter have at it.
The Audubon Field Guide is pretty good for ID and leaf/twig/bark details, but some of the bark pics in the picture section don't look like what I see here.
So here are 2 splits.
1 st 4 pics is White Oak and hoping to confirm with these pics 0888-0891
2nd 4 pics is supposed to be "chestnut" not sure if they meant chestnut oak or just chestnut? 0892-0895
Edit: this is strange, every different time i open this the first 4 pics switch places with the other 4 pics.
Here is a better close up of the oak end grain
The above splits came from this load.
I think the large diameter logs with the deeper thicker bark might be chestnut oak? It is what the guy said is chestnut. The other stuff in the pic i'm almost sure is white oak.
There is more of this "chestnut" available and i'll go get a load or 2 if it is indeed Chestnut OAK and not chestnut.
Reactions: Dieselhead
All Oak, it appears to me from the end grain with distinct rays. I see White Oak bark there, but I've never seen Chestnut Oak bark. The deep-ridged bark stuff in his pic has an Oak-looking end cut as far as the sapwood-heartwood appearance. Blurry pics, though, so hard to say much more.
But the bark in your 0892-0895 isn't the deep-ridged bark...looks more like White bark.
There's a chestnut oak A couple towns from me. I took out a bunch of red pine there 2 years ago. They were dominating the sky and the oak was living in the shade....was. If I remember correctly, the bark had more of a iron wood look to it. It at least reminded me of it.
Another strange oak I've seen in the hills is saw tooth oak. The leaf edges, had teeth like a hand saw. It's growing on a lakes edge. I had to hit that ID on the phone app. Was noted to be toxic to humans.
The older I get, the more tree species I discover.
Reactions: bigealta
The guy's marketplace add is still up, so i just texted him to see if i can get a load tomorrow.
