LLigetfa is still around
LLigetfa
7,377
NW Ontario
After years of not burning wood as my primary heat source on the wife's, she relented and had me tight a fire in the evenings this Fall. How long this lasts. who knows.
A few years ago, I sold (at below cost) half of my firewood and emptied out my woodshed of the other half in order to remediate / convert it to closed in workshop. I built on two lean-to additions for firewood storage (to use for backup heat).
[Hearth.com] LLigetfa is still around
I have moved half of my remaining half under the right side lean-to that I am saving for emergencies and have been taking from the other half stacked outside for burning . I do plan to move the rest of it to the left side lean-to eventually.
I have almost run out of my SuperCedar fire starter as well as my stockpile of kindling. Herein lies my dilemma. I don't know how long I will be able to burn wood before the wife bans it again so I will locally source fire starter and split kindling from the old firewood.
I was forced into retirement due to a stroke and my axemanship has suffered as a result so not as adept at making kindling so I need an alternative.
Nice setup. I have seen pictures of kindling "tools" although they may all be homemade. Take care of yourself.
Yesterday I resorted to using a small hatchet by pounding it on the pol with a metal mallet but that is sacrilegious to the hatchet. A wooden mallet would have been kinder to the hatchet. One thought is to acquire and use a small froe which is meant to be pounded.
There also exist firewood crackers that stand with the blade facing up where the wood stands upright and is stuck with a mallet.
Lastly there are wall mount kindling splitters with a blade that is pulled down into the wood.
You can always buy a 2x4, and if you have a table saw in your shop, go from there.
A bag of pellets (for a pellet stove) works well too.
Reactions: Turbo89
Great idea, probably can grab the bent and warped 2x4s for cheap at your local Home Depot or Lowe’s or equivalent. I love using carpentry scraps as kindling, you can practically light it with a match because it’s so dry.
Reactions: stoveliker
I would probably find a little cheap electric log splitter. Use it for kindling and to split a little - handy machines.
Just to add. Consider wearing eye protection when pounding a steel hatchet with a steel hammer.
Take a look at amazon.com for one of these or they might sell them elsewhere. No axe required.
  • [Hearth.com] LLigetfa is still around
I do have a table saw but it would not be ideal. First off, my shop is tiny so it is folded up and needs to be rolled outside and setup. Second, the cut is too smooth and not ideal for fire starter. Rough cut/splintered is better. Third, my doctor said I should not use power tools due to poor coordination. I do use it but it is heavily guarded and cumbersum.
It looks like I need to update my sig. My log splitter is on long term loan to my neighbor, my woodshed can no longer hold 12 cord, and the dog died.
Yes, that wall mount splitter was one of the options I linked to on Home Hardware but t is not in stock so I have to buy it sight unseen. I would like some feedback from someone that uses one. My first thought was having to bend down to tick up the wood that falls to the floor would be a pain. I suppose I could mount it low on the wall and operate it sitting on a stool. Another option would be to mount it horizontal on a bench so the splits don't fall to the floor.
If you see it on line, there should be reviews also. You could wall mount it, and have a shelf under it to hold a bin. Once the bin is full you can carry the kindling. If it's mostly steel construction then you should be able to replace the pins ect.
I go to the local lumber yard and pick up the slats the bundles of lumber are packed with. They are about 1/4" thick and various lengths that snap easily. I use them for shims when doing any construction projects and break the rest up for kindling. I also get hardwood scraps from a cabinet shop. Both of these are kiln dried and light easily with a scrap of paper. I've got better thimngs to do then split kindling and not spending money on fire starters.
BTW, this is what I make for kindling. Those 5 bundles of ash I split back in 2009.
To make those long skinny pieces you need very straight grained wood that slits easily along the grain. It take a sharp thin blade that can follow the grain. I wonder if a froe that is used for making shakes would be better suited for the job? From what I've seen of those wall mount gadgets, the have a thick, blunt edge like a spitting maul.
Reactions: begreen and Turbo89
One thing I used to get was the trim offs from a local lumber yard. They were hardwood, and various lengths. They would be 1 inch wide, and maybe 1/8 to 3/8 thick and always a taper. The lumber yard would put them out in a roadside bin. If your timing was good, you could get as many as you wanted. One day I picked out a huge bundle and still have some. Very useful for renovations ect, but would make excellent kindling as you would just cut it with a miter saw.
I think that kindling is overrated.
I have a bag of splitter trash the bag contained 20 lbs of bird seed.
That's all I use in a winter.
If the splits are sufficiently dry, I don't need more to get the fire going. And I've used a cut up 2*4 initially. Those are so dry that it being smoothly cut didn't matter.
My point being that if splits and kindling is sufficiently dry, you don't need much at all. Two of those pieces from your bundles to get a load going (with a propane torch).
BTW, this is what I make for kindling. Those 5 bundles of ash I split back in 2009.View attachment 350217
Back in 2009 when I split all that kindling, I used a small axe with a fine edge on a 2 1/2" head and 24" curved dandle. I would balance the wood on the chopping block with one hand and swing the axe with the other hand. If it did not split with one blow, I would choke up on the handle and lift and drop the wood back on the block letting the weight of the axe finish the job.
Years later, when I stopped burning wood, I had the misfortune of ruining that axe on a rock and never got around to fixing it. Mind you, my aim is so poor now that I can no longer do it that way. None the less, I started to put a new edge on it.
I like the 2x4 and scrap lumber ideas. Can u use a sawzall? They work great. Also those mini 1 hand battery chainsaws are great too but maybe that’s too dangerous? I’ve seen really small ones that are used for trimming small branches and they’re more like a scissor so they have a protective cover over the chain.
There were huge gouges on the edge that required a lot of metal to be removed. A dry grindstone would have created too much heat. A flap disk in my angle grinder and and coarse belt in my belt sander made quick work of removing material without so much heat but those are difficult to maintain the right edge profile. Finishing it off with a file using the "draw" method made quick work of restoring the profile.
BTW, I and meant to write 2 1/2 # (pound) head. Before my stroke, I could touch type accurately. Now it's hunt-and-peck with lots of mistakes.
The edge profile of a shake froe is likely different than a riving froe. A shake froe likely has a blunt edge to create a tapered shake while a riving froe is thinner in order to be able to "steer" the spit along the grain. Mind you, riving is generally done with green wood, not seasoned wood but some of the same principals still apply.
I like how he holds the back of the file steady vs drawing with both hands moving.
That is a good idea. I could park a wheelbarrow under it to hold both the yet-to-be-split wood, the finished kindling, and the splitter trash to cart away so I won't have to clean a mess on the floor. I could also put the trash in LCBO paper bags and toss it in the stove for kindling.
I'm down to the bottom of the case lot of unwrapped Super Cedar Firestarter pucks and was surprised how much of the pucks disintegrated into sawdust during shipping. I am putting it into paper cupcake liners and placing them in the stove as Firestarter. Meanwhile, I picked a couple of packages of firestarter cubes and later found that they are so heavily scented with perfume that the stink up the whole house . No way I can leave them in the house. I'll have to keep them outside and bring them in a cube at a time. I don't know what they were thinking adding scent to them. The Super Cedars just have a mild natural cedar scent.
There's probably some good homemade firestarters you could make. You could get some box cardboard, cut 2 inch lengths, roll them up and tie with wire. The dip in candlewax. I used to make my own candles. You just need a pot and some cheap wax.
