LLigetfa is still around
I like how he holds the back of the file steady vs drawing with both hands moving.
I am less coordinated so had to improvise when I sharpened my pulaski.
[Hearth.com] LLigetfa is still around
One thing I used to get was the trim offs from a local lumber yard. They were hardwood, and various lengths. They would be 1 inch wide, and maybe 1/8 to 3/8 thick and always a taper. The lumber yard would put them out in a roadside bin. If your timing was good, you could get as many as you wanted. One day I picked out a huge bundle and still have some. Very useful for renovations ect, but would make excellent kindling as you would just cut it with a miter saw.
In the past, I've scored nicely with finishing trim cutoffs from contractors and from cabinet makers. That works great. Lately, I have enough splitter trash to start a fire easily, but I'm burning softwood. It doesn't take much to get it started.
I’m done burning cardboard diy firestarters after reading this.
Burning brown cardboard produces a complex mixture of toxic gases, heavy metals, and carcinogenic chemical compounds. While raw wood pulp burns relatively cleanly, modern brown cardboard shipping boxes and packaging are treated with adhesives, synthetic polymers, and colored inks that create dangerous airborne pollutants when combusted. [1, 2]
Toxic Byproducts and Chemicals
  • Dioxins and Furans: These are highly potent, bioaccumulative human carcinogens and endocrine disruptors. According to the US EPA, burning paper and cardboard packaging is a primary source of backyard dioxin emissions, which settle into the local environment and food chains.
    [1, 2]
  • Volatile Organic Compounds (VOCs): The burning process releases harmful gases like benzene, formaldehyde, xylene, and acrolein. These compounds irritate the respiratory tract, cause headaches or nausea, and pose long-term cancer risks. [1, 2, 3]
  • Heavy Metals: Modern brown cardboard uses chemical bleaches, binders, and inks that often contain trace amounts of heavy metals like lead, cadmium, mercury, and arsenic. These metals do not destroy during combustion; instead, they enter the smoke or concentrate as hazardous residues in the remaining ash. [1, 2, 3, 4]
  • Carbon Monoxide (CO): Cardboard is dense and often burns incompletely or smolders. This incomplete combustion generates high levels of carbon monoxide, an odorless, toxic gas that reduces oxygen delivery throughout the body. [1]
  • Fine Particulate Matter (PM2.5): Cardboard creates massive amounts of lightweight, floating ash and microscopic soot particles. When inhaled, PM2.5 bypasses the body's natural respiratory filters, lodging deep in the lungs and aggravating asthma or heart disease. [1, 2]
The Minnesota Pollution Control Agency warns that even seemingly harmless items like unbleached shipping boxes or frozen pizza packaging produce hazardous mixtures because of modern manufacturing additives.
I picked up a box of these starters last December. They are parafin and pine sawdust and work well. I'm breaking them in half which equals 200 starts.
Fire starting nuggets
    [1, 2]
Probably all true.
However, they should compare it to the same combustion products when burning cord wood. Most of these things will likely also be produced burning cord wood. (Even heavy metals in trace amounts.) The question is what the amounts are compared to wood.
Yet, I use splitting trash and noodles. That's the same as the wood I'm burning and I have too much of it anyway.
Given the current tariff war between the US and Canada, I decided buy local. I should have read the reviews on the
Great but highly scented​
Jan 21, 2023
It works wonderfully, however if you're sensitive to scents, pass this one. It seems that the recycled wax may be from used candles, because it was strongly scented like a Yankee brand candle... smelled like that ubiquitous potpourri from the late 80s/early 90s.. you know the kind. Other than the scent, it truly works wonderfully.
