Wood pellets what good hardwood pellets
What a good hard wood pellets have quadfire classic bay 1200
Why hardwood? Hardwood pellets are not better...I burn softwood. There is a brand I found from southern pine down there but now I'd have to look it up....
EasyBlaze.. just a tick or so below douglas firs in BTU and low ash..
Buy 4 or 5 bags of what is available where you live
See which one works for you
I use Cubex 100% hardwood and Fusion Blend 80% hardwood
Both from a wood flooring mill in Quebec, Canada
Each stove reacts differently to pellet quality. I have an old Whitfield Quest and it prefers a high quality low as softwood pellet. I gtmm my et low ash, high heat, and little buildup on the glass.
Try multiple bags of different pellets and decide what trade offs you are willing to make.
This, right here. My P61a LOVES hardwoods and dislikes high percentage, or 100% softies. If the OP's question is purely on heat output, these are what I've measured the air output from my P43 to be for the brands I've tried (note, GS has two different HWs and they are not the same).
[Hearth.com] Wood pellets  what good hardwood pellets
Also, the Cubex and Fusion produced little ash while both GS had more ash (the Midwesterns are actually as ashy as mid-priced blends)
Reactions: ABusWrench
that's the ones!!! EZBlaze...
Very Cold Hardwood Cubex
Fall and Spring Fusion Blend 20% soft wood, 80 % hardwood
Both were made by the same wood flooring company in Quebec
Reactions: Charles1234
I try ez blades and awf American wood fibers seem the burn fast had stove installed march went through bag and half a day and had feed on slowest setting. I did like them both going get 2 tons of soft woods just not sure what ones either ez our awf and get too tones hardwood
