The cleanout door opening is going to rapidly cool down flue gases and exacerbate the situation. Is the latch broken? Normally it would take a strong bit of pressure to open it.
Is there an insulated stainless liner in the chimney?
Yes insulated steel liner. Latch catches on but not by a lot.
If there is an insulated liner with a capped tee, how is it pressurizing the cleanout door? Is the top cap sealed?Yes insulated steel liner. Latch catches on but not by a lot.
You mentioned earlier that you pulled the cap from the tee and the draft improved.“Capped tee” ??? The liner runs top to bottom and has a weather cap not sealed at top. The thimble “t” is about 4 feet up from clean out. I can’t recall but I think it standard type for liners. Insulated blanket around liner the tiles are not filled with insulation
How did you do this if the cap on the tee is 4' up from the clean out?I ended up pull clean out cap off bottom of T and it started drafting.
Two different people, slocum pulled the cap from “t” I don’t have a clean out “t” just the standard clean out chimney door which puffed open. [emoji6]
So is there a cap at the bottom end of your insulated stainless liner and a tee at the thimble?I'd get a cap on the end of the liner. That could be the issue right there.
