Confused newbie wants wood stove insert for 1900' log home that has fireplace with no hearth extension. Floor of firebox does not extend out to reach stone exterior. Firebox floor meets laminate floor covered with two layers of Imperial stove board that are R1.5 each. Opening is 34.5 high so can raise 23"high insert 5-6" if need. Don't want to cut up floor and work in crawl space to support heavy hearth. Read but dont understand manuals and threads. Not sure if cutting a nice hearth pad is possible. Waiting for chimney guy to asses and install but want to make plan prior. Will never use as regular fireplace. Manuals say floor protection but not clear if ember or heat or both, and bc front of insert sticks out of existing firebox does that change things? Flush ones look better but afraid wont get enough heat and may still need to be pulled forward enough to be even with rocks on exterior of fireplace, so still will be outside of firebox. Also want to eliminate faceplate surround bc will stick out quite far bc of rocks, wont look good, and want access to top to cook or boil water in outage. Freestander not option bc clearances to combustibles in room like rug and wood legs of mantle, and dont have the space. Think chimney is only 12' so insert choices limited. So, can insert's front sit on R3 stove board over combustibles? if raise insert would it be ok? THANKS SO MUCH for any input
![[Hearth.com] wood stove insert hearth and floor protection [Hearth.com] wood stove insert hearth and floor protection](https://www.hearth.com/talk/data/attachments/284/284045-318098c5949ca464e4dae489969e81f0.jpg?hash=ICexFExZK_)
