rideau
Best way to limit heat output is to burn one or two large splits. Keep your fuel quantity down, split size up, air closed down. You get a long, slow, low burn.
There are a lot of things wrong with that chart.Way off-topic... but I'm confused by that graph. How does a big cast iron stove like the Jotul Firelight 600 rate so incredibly low on max BTU/hr., while a soapstone stove marketed so strongly for its ability to moderate temperature swings, rates so high on max BTU/hr. for an EPA test load?
I guess we need more info under the obviously disparate conditions under which each stove was tested.Do you really think the 3.4 cu ft Drolet puts out twice as much heat as the 30NC?Obviously disparate conditiond? I thought one thing we could all agree on is that the EPA tests test all the stoves under the same conditions? In a test lab, loaded with a full firebox of dimensional Doug Fir?
Do you really think the Mansfield puts out more heat than the Equinox?
Do you really think the Encore puts out more heat than the 30NC?
Do you really think the Fireview puts out more heat than the Equinox?
Let's pretend that is all true for a moment.I'm not defending the EPA's tests as I know nothing about them. But any stove can output completely different than any other stove of the same type (cat, non-cat...) and size, based on the rest of it's design characteristics. How the air flows through it, materials, how it exhausts, does the exhaust exit the stove too hot (aka wasted heat) or is the heat extracted and emmited from the stove.... these can ALL make a huge difference. You seem to have this very weird idea that all things the same size are made and work exactly the same. With my scientific and engineering background, I can assure you that is not the case.
Explain how a non-cat, burn tube and baffle board, 3.4 cu ft steel stove puts out twice as much heat as a non-cat, burn tube and baffle board, 3.5 cu ft steel stove.
I mean, I'm CURRENTLY RUNNING an Encore and a 30. The chart shows the Encore puts out more heat even though I experience that every day that is not the case. Not even close to the case. The 30 out heats the Encore and Heritage (which I have also owner) by massive leaps, both of which in the chart put out more heat than the 30.
The chart is useless, inaccurate, and does more harm than good.
That is just one of many inaccuracies with that chart. The Mansfield/Equinox is equally laughable.I completely believe your experience with the stoves. So my question would be WHY isn't the 30 testing that way? You own the 30. Why don't you call and discuss it with the manufacturer? They should have an interest in seeing that their stove is properly represented. And, out of curiosity, what does THEIR literature say about real life heat output and burn time of the 30? Do they list it with a more accurate representation?
As rideau mentioned, the one thing we do know is they are all tested in the exact same manner. I do scientific tests all the time, you would be suprised at how different the results are normally from what we "thought" they would be.
Unfortunately, you are both incorrect. The EPA test for emissions uses a load of varying size, based on firebox size. Because this graph was presented as data based on the EPA emissions testing, the conditions are disparate, in that the various size stoves are tested with different loads of wood.
http://www.woodheat.org/emissions-testing.html
I don't think anyone here is knocking your beloved Woodstock's performance, so there's no need to get heated over this, rideau.
edit: Waulie nailed the underlying theme.
No. They do not.But the heat output is used as a reference for "classing" the stoves. Similar to how cars and trucks are on a certain "class", and must meet the emmisions rules for that "class". So the heat ouputs might not be dead on (as I think we all agree), but they do make a decent reference point.
The reported epa outputs don't mean much. The EPA doesn't really care about ouput, it cares about pollution.
No. They do not.
The Progress does not put out three times as much heat as the 30.
The Drolet does not put out twice as much heat as the 30.
The Oslo does not put out more heat than the Encore and the 30
The Mansfield does not produce more heat than the Equinox.
The Fireview does not put out more heat than the Equinox.
The Encore and Heritage do not put out more heat than the 30.
Some of these I know from personal experience (30, Encore, Heritage, Fireview, Oslo). Others are purely common sense. It is a chart that should be ignored and offers zero value in term of how a stove will heat your home.
I don't think you are reading this correctly. Are you taking into consideration the fact it is ONLY comparing MAXIMUM BTU OUTPUT? The chart is not saying "a Progress puts out 3 times as much heat as a 30". It is saying, with a full load of EPA test wood, the MAXIMUM heat each unit will put out is xxx btu's. That does not mean it can do it for very long, or very short, or any lenght of time for that matter. Just that it can do it.
Here's an experiment for you to try someday. Load all three of your stoves with the same amount of the same type wood. Say, two 4 lb splits of oak for examle in each stove. Light them up, and leave them full blast open. Now measure (as best you can), how much heat each seems to put out, and how long it takes each one to burn down to the same point (10 or 20% left in coals). THAT, is what I believe they are showing you in the graph.
Does it show you exactly what a stove will do in your home? of course not. Nobody is saying that. It is a reference point.
It is ridiculously wrong.I don't think you are reading this correctly. Are you taking into consideration the fact it is ONLY comparing MAXIMUM BTU OUTPUT? The chart is not saying "a Progress puts out 3 times as much heat as a 30". It is saying, with a full load of EPA test wood, the MAXIMUM heat each unit will put out is xxx btu's. That does not mean it can do it for very long, or very short, or any lenght of time for that matter. Just that it can do it.
No, it is not what they are showing. AND, the 30 easily puts out more heat with the same amount of wood than the Encore. Which isn't even what the original chart is showing.Here's an experiment for you to try someday. Load all three of your stoves with the same amount of the same type wood. Say, two 4 lb splits of oak for examle in each stove. Light them up, and leave them full blast open. Now measure (as best you can), how much heat each seems to put out, and how long it takes each one to burn down to the same point (10 or 20% left in coals). THAT, is what I believe they are showing you in the graph.
A really bad reference point that offers no value.It is a reference point.
Right, but it is implied by comments like "highest output ever". Look, I don't really blame WS for touting the test results. At least they actually are test results. Plenty of manufacturers come up with claims which seem to be based on nothing at all.
The interesting thing to take from the test results is that the PH must still be heating very efficiently to put out that much heat with the draft full open. While other stoves are probably sending a lot of the heat up the flue with the draft full open, the PH is still sending it into the room. I've noticed that while you get lots of air with the draft full open, the stove still heats up very fast. If I leave the draft full open very long on a hot coal reload, I'll often have secondaries like crazy before the flue is even indicating cat range. The heat exchanger fins definitely helps. Also, the slanted baffle pointed directly out the window sends a lot of heat into the room quickly.
Or, it could just mean the PH burned through that EPA test load very fast with the draft full open. It's probably a combination of the two.
Of course this doesn't really mean anything for heating our homes. It is interesting, but that's about it. I suppose it goes to the efficiency since you aren't losing as much heat up the flue as you're getting your fire going and getting your stove up to temp.
The chart is not inaccurate. It just reports the EPA test results. However, it is certainly misleading.
Please point out the post in which I have said that. You are the one that stated this: "Load all three of your stoves with the same amount of the same type wood. "For example, BB seems to think it is stating one stove puts out "more heat with the same load as another stove".
And I believe it is completely worthless and offers no value as to how a stove heats your home.It says nothing of the sort. It's simply a measure of the SPIKE of maximum heat output of each stove with the appropriate amount of EPA test wood based on firebox size. I beleive it is the best reference point we currenlty have besides user input, but user input tends to be off kilter even more.
