I'm a little irritated with the plumber that did all the original plumbing in my house.
I put a zone in my basement this winter and used Haydon 1000 baseboard and I am really happy at the heat I get out of it at low tank temps. I had planned on swapping out original baseboard in the house with the Haydon 1000. However, when I took off one of the upstairs covers I didn't really recognize the fittings, so I contacted my local supply guy and he explained to me that it is Wirsbo - takes different tools (pretty expensive) and comes in kind of odd sizes. I already have all my regular pex tools that I bought for the winter project. The downstairs is all regular pex. I'm not a plumber but that seems kind of sloppy to me.
The other thing is, I sent my supply guy a picture and he is concerned I don't have enough slack sticking up above the floor to cut the Wirsbo tubing (to remove the baseboard) and then have enough room to get a Wirsbo expander fitting down over without bumping up against the floor.
I asked him if I could cut the existing wirsbo tubing, put in a male to male connector and then splice in a short section of the Shark Bite pex I bought from him last winter (I still have 20 or so feet of it), and then use a 90 degree copper fitting to go into the baseboard. He's not sure that the inside diameters will match up. He's a supplier, and as much as he'd like to sell me the baseboard, I think he is afraid of giving me bad advice and putting me in a bad spot.
Anyone ever deal with this? If I can splice in a short (3-4 inch) section of regular pex I think I'm in good shape.
Thanks
Thanks
. The 5/8 tube should have almost no bearing on how your upstairs heats vs. the 3/4. As I'm sure you already know it's the amount of BB, and if your going with Haydon 1000 you'll have much higher output/foot even at lower temps which is what you desire for storage.
), why you can't use a crimp tool with the 5/8"? Just trying to understand the difference.
