Would you fire up your wood-burning stove with temperatures like these
Itslay90
720
Upstate,NY
Would you fire up your wood-burning stove with temperatures like these, or would you wait until it gets colder? My house is 57 degrees right now
  • [Hearth.com] Would you fire up your wood-burning stove with temperatures like these
Would, and have.
I'd end up paying for a hotel room for the rest of the family if I didn't fire up well before 57*! !!!
I'll shoot for low 70's, then let it coast back down before reloading...might be fire 1X/day, or even 2 days...just depends on weather, and sometimes what is going on in the house (baking?)
Reactions: Itslay90
Yes I like my place in the mid 70’s
Yes. Have been burning on and off for the last 3 weeks. Typically start a fire in the evening and let it burn out. Usually re-split my splits to smaller size and burn a hotter fire. Temperature and forecast determine how much wood goes in the firebox.
Reactions: Geezer77
My chimney is tough to start from cold if it's above 40F or so outside, but if it looks like a dreary day I'll do it anyway. If it's above 45 or so with sun, the stove will roast me out even with a moderate load of fuel.
Reactions: NickW and Itslay90
Fri-Sun in your screenshot: yes. After that, no.
I fire up when it's below 40-45 or so for 24 hrs or more, given that my stove runs so long on a load.
My stove is in the basement, which gets nice and toasty at 80+, and upstairs I keep it around 70-71.
My mini split is running, when the stove is not on, as they're very efficient at these temps. (And I am no longer paying for kWhs.)
Reactions: Itslay90
The temps posted in OP, definitely not. Mini Splits are perfect. But we’re about to get nights in the 20s and also 30s with rain and snow on some nights. That’s where the mini splits start to be less ideal. Also I’ve got lots of wood. Late this week starts nightly fires and some mornings too probably.
Reactions: Itslay90
We have the nights drop down into lower 40's, maybe touch the 30's, but then back up to 60's during the day. I haven't been firing up the ole dragon.
Nice. How much wood do you have ??
That has been my modus operandi as well.
Reactions: Murray01
I'd be doing (and have been) an overnight hardwood load with a shoulder season load in the morning. On the cooler, cloudy days I might keep it going with small shoulder season loads.
Reactions: MRD1985
Below 38-40 degrees at night I use it. If it doesn’t get above 45 day time I’ll also use it. Otherwise mini splits. Gas fired boiler as last resort back up.
With a high of 46 on Friday with rain I’ll probably have a morning and night fire
Reactions: stoveliker
We get great passive solar, so if is sunny during the day, we don’t need a fire even down to around freezing or a little below. That said, cloudy and 30s or 40s and the house cools off pretty steadily. Obviously large fires are not needed, but I start burning around now when we get these cloudy cooler stretches. I keep all of my spruce for shoulder season wood and just burn that in smaller fires until winter cold arrives.
40 or 41 degrees during the day cooling to 30's in the evening yes. 50's during the day...no. We would end up opening windows. LOL I have a heat pump. I let that do the work. I save my wood for colder days.
Sitting down knitting, yes, working outside with breaks inside in between, no. Don't want that Grandma warm. It's bad enough I get hot flashes at 71 degrees with humidity above 60. Windy outside, definitely, as this poorly constructed Arkansas house doesn't have much insulation with vinyl siding. Oh, and don't forget about cooking, which in itself heats up the main rooms.
Reactions: Todd
I don’t know, because I haven’t bought any of it, stacks are irregular and unmeasured. Maybe 8 cords total but only some of that is very dry.
I’ve got two woodsheds jammed full. The one closest to the house, burn first, has usually been stacked with most sections dry and some for next year, not dry yet. This year it’s all dry and stacked to the roof. Lots of ash. A fair bit of maple, which I’ll test once I hit that. Some pine, which is quite dry.
The more distant next-year-and-beyond shed has probably six cords. The oldest ash and maple in there is pretty close to dry, and there is a whole lot of eastern white pine that has been split and stacked for months. I wouldn’t burn that now, but by spring it would be way more shoulder season wood than I could use.
I have had a handful of fires, but now we’ve got another long stretch of mini-split weather. Haven’t made a tiny dent in the wood store yet.
I’m gonna fire up the wood boiler today and temps will be in the 40-50’s the next week or so. Mama Bear is getting “cold feet” so it’s time to fire up the in floor heat. Historically I’ve waited until it’s in the 20’s overnight and 30’s during the day but I stuck a Boiler Commander on it for this season and have hopes it’ll reduce the amount of gooey stuff built up when it sits and idles for 4-5hrs between burns due to warm outdoor temps. We shall see !! Either way I’m excited to get it fired up. I love burning wood.
I’m usually not chomping at the bit to start moving wood through the stove in shoulder season. Heat pumps are perfect in the 40s. There will be plenty of dealing with wood for the winter. I’ve had conversations with a friend with a heat pump about fires before it’s cold. “You’ll have all winter dealing with wood, and you’ll be sick of it.” This year, we’ve got a couple of colder days coming up, but after that we’re back to days in the 40s. I’m actually eager to burn wood this year. It’s just creepy how mild it is heading into December. This is Vermont.
What I’m seeing aground, and smelling, is that there is a whole lot of smoldery wood burning happening all around. Lots of oil heat in the state, oil + wood. I think waaay more people are burning wood not shoulder season oil (now $6 a gallon), and burning the stove low at 45F outdoors. They do not have Blaze King stoves, but probably lots of old smoke dragons. The other day I drove across the state, mild day, so many chimneys with thick smoke. A couple of my neighbors got their winter wood delivered then stacked for this winter, this fall. Now they are burning that wet wood slow and cool. Yesterday I was out cutting and stacking some wood and I could smell wet sugar maple catching fire in a stove (or trying to). Reminded me of the late 70s when I and all my friends used to do that. Distinctive smell, actually very nice as it’s just catching fire. Really a maple syrup smell. Smells good when it’s just wet sugary sap evaporating. Then noxious after a while.
Those old stoves and green wood, still not great when it’s cold, burning as hot as possible, are at least better in that situation. Awful in mild weather. It’s just amazing that here in northern New England, with a long and continuous history of wood burning, more people haven’t learned how to burn. File it under “Things your dad taught you that were wrong.”
Reactions: Dieselhead
