Just starting out
FortBevon
2
Pennsylvania
Hello all,
This is my first time posting and new to hearth.com. I live in a town home that is 3 levels and about 2000-2200 sq ft. I live in Pa where the winters can get pretty cold and I’m looking for a wood stove insert for my fireplace. Currently have hvac but I would like a wood stove fireplace for 1.) For helping reduce power costs for longer stretches of cold spells and 2.) wanting a contingent plan if power goes out.
Been in the house 3 years and haven’t used the fireplace. Got it cleaned out when we first moved in and there were some fixes recommended like fixing some of the mortar between the bricks, and sealing some of the cracks that apparently leaks into/down the chimney. Other than that there were not major concerns.
The questions I have are:
1.) Any recommendations for inserts that have automated vents to help with air intake that don’t need electricity. I would like to find one that has a battery powered fan in case of losing power.
2.) Do I need to fix my chimney before adding the insert?
3.) I’m pretty handy and have been educating myself, how hard or practical is it to install an insert myself? Do you have any tips/tricks/suggestions or things to look out for? Are there any stipulations that you all have run across from a home insurance perspective and DIY vs. Professional/accredited install?
4.) your experience, is it worth it when it’s colder out if I have a heatpump. Does you house or room become too hot/hard to maintain a constant comfortable temperature?
Welcome. A picture of the current setup would help if possible.
Is this a prefabricated metal fireplace or a full masonry fireplace with a masonry chimney and clay tile flue? What level is the fireplace on?
Reactions: FortBevon
As for the heat pump part of it. I have mini splits, which I use until it gets below 32 more or less, with a lot of slack around that number. The heat pumps are cold weather units, good to -15F or whatever, but they are expensive and not as comfortable as wood when it gets really cold. Of course my house, climate (cold), insulation, etc are different from yours. Wood heat is less expensive and more comfortable in cold weather, heat pumps are fabulous in milder weather, super efficient. I just “feather” the heat pumps and wood stove as I start to use less of the heat pumps and more of the stove. Just use the heat pumps less around periods when you have fires, turn off altogether if you can get away with that as you move into cold weather and use wood a lot more.
Be aware that to get going burning wood you will need a supply of dry wood. It might be difficult or expensive or both to get that the first year, and it may not be dry enough to burn when you get it anyway. The best way to get dry wood is to buy it a year or two in advance.
I also like to DIY stuff myself, but with chimney stuff IMO it is far better to have a pro involved. Insurance probably will like it that a pro is involved. Worse possible outcome of not doing it right is fire or smoke issues, and insurance not covering you.
A combo of heat pump and stove/insert is great. The former does well (efficient, cost) when you want some heat but it is still not crazy cold out. The latter might not do well when it's warmer (draft issues) and does great when it's cold out.
I have mini splits that I use to heat with also, and I only use my stove when it's below 40 -45 for 24 hrs or more or so.
So quite a few cold starts in the shoulder season.
We have had heat pump heating since 2006 and last year updated the system to a high-efficiency combo. It's wonderful for shoulder season heating and the new system can handle the cold weather too. That said, we still love the bone-warming heat of the stove and the glow of a fire. Our cat heartily agrees.
[Hearth.com] Just starting out
Thank you all for the replies! This is the current set up. About 34.5 inches wide and 22.5 depth. We had it inspected/cleaned a couple of years ago when we first moved in but haven’t used it. He said the mortar needs to be fixed and filled. There might be crack by s on the outside of the chimney and some leaks coming through. The top of the chimney around the cap. I have 2 year old twin daughters as well and am worried about them getting around any barriers to a hot insert. Fire place is on the first level.
  • [Hearth.com] Just starting out
Kids learn quick and understand hot. In the rare instance that they did touch the stove, they learn their lesson and it will never happen again.
I’m not so sure about that 🤦🏻‍♂️
*his* kids learn fast... ;-)
I think the issue with safety can be relevant. Not because of curiosity "let me touch that stove" (indeed that'll get learned quickly), but because of accidents. Running around and falling/bumping into the stove can happen.
