Would you, or wouldnt you?
Blue Vomit
662
eastern PA
The Pros:
about 40 foot of standing dead primo black locust
straight, no bends, almost no bark
similar tree next to it measured about 15% on the MM https://www.hearth.com/talk/threads/excellent-small-score.91139/
back the truck right up to it
about 2 miles from home
The Cons:
Im assuming that vine is poisen ivy
that may be the biggest poisen ivy vine Ive seen in a long time
I get poisen ivy, although not real bad
the vine goes all the way up the 40 foot tree
What say you?
[Hearth.com] Would you, or wouldnt you?[Hearth.com] Would you, or wouldnt you?
Reactions: ScotO
Take it....Just make sure any coats sweat-shirts are washed afterwards. I dont think thats PI.
Looks like PI to me. I'd pass.
Reactions: Blue Vomit
Cut it up and take a shower.
If that really is poisen ivy You should call the Guiness book of world records cuz I aint NEVER seen any that big. If you can get that vine pried offn that tree once its down I'ld say slap on some gloves and go for it!
you trying to say poison ivy might deter you ??
yup, im a bit of a wood snob and this might just push me over the edge. Normally I wouldnt think twice about BL, but I would rather not be scratching myself silly for the next few weeks. The wife says I scratch myself enough without poisen ivy.
Reactions: ditchrider
Buy some cheap gloves that you can throw away and get some technu, cut it, toss the gloves and take a shower scrubbing yourself with the technu, only drawback is the technu stinks.
Anyone else in your family have bad reactions with poison ivy? You're gonna have to cut that vine and pull it off the trunk. The oils are sure to get everywhere. I have no reaction, but my if my wife so much as walks near poison ivy, she starts to itch. So even if I c/s/s the wood, there is a high probability that she might put a log on two on the fire at some point....and then wonder how she got poison ivy in the middle of winter..
when i have serious poison ivy vines to deal with, i go the the thrift store and buy the cheepest used clothes i can find, usually less that $5 for pants and long sleeve shirt. some cotton or old used work gloves, i put vinyl gloves over the work gloves, rip off the poison ivy, take all the outerwear and throw them in the trash.
i would not pass up sweet black locust score.
Yes that's poison ivy. Cut the vine with an ax an pull off tree once its down. Wear long sleeves and gloves. Do not cut the vine with the chainsaw unless you want to spray it all over.
I cut about 30 cherry trees down with poison ivy one had a vine even larger then the one you are looking at. See any white berries? They might be dried up now. But they are to be avoided as well. Good luck.
I knew I dude that used to EAT poison ivy leaves swearing that it kept him immune. I dunno I don't have the nads to try it.
Sent from my rooted and eclipse running X2--thanks nitro-- if im posting on here I'm probably supposed to be working! I can't help im addicted to HEARTH.COM!
I would also pass on the tree or wait until the dead of winter when the oils are not as active
that is too big of a vine to not get any on you
I would confirm that it is or is not Poison Ivy. Shouldn't be hard to confirm. Any leaves?
I have cut the vines and wrapped a chain to it and the truck to pull vines off trees before. Just make sure you are far enough away so any falling limbs that get pulled off too misses you. I have a long 1/2 " cable and a long Kevlar line for those purposes or when I need to add some influence while felling a leaner.
I'd take it, I come across vines like this and am careful, I do get a little rash sometimes...get the BL every time...
I like the idea of jusr pulling it off the standing tree with a truck. Cut the bottom with an axe wrap a chain and go for it! Too much good wood there to pass up.
How sure are we this is poison ivy and not grape. Anything approaching that big at my place is grape.Someday I'll post a picture of my biggest grape, out by the gate. It's a good 6 inches or more in diameter.
I would get it done.
