Had a Lopi Leyden stove installed in front of my old existing fireplace. It is vented to the rear of the stove with a pipe to a "T" connection where it connects to a stainless steel 8 inch chimney liner up thru the existing masonry fireplace chimney. Our first fire was Xmas day and we've been burning pretty much 24/7 since. It was installed by a professional whose company is well established & respected. My question is this: Where the horizontal pipe that vents to the rear of the stove and connects to the "T", there is a gap of about 1/8 inch, and you can see inside the pipe. I questioned the installer about this and he said that it was common, and that that is the way it is designed and manufactured, and there is usually not a real tight fit/seal. I had a fire inspector look and he said that he had never seen it before but didn't feel it would be a safety hazard. I called Travis Industries (maker of the stove) and they stated that they felt that the entire system should be closed, but they only manufactured the stove, not the liner. Anyway, today I loaded it up about 3/4 way with pallet wood and when she got hot (about 650 degrees) I could hear the rushing of air and see thru this gap that there was a fire inside the pipes at the "T" connection. (This "T" is only about 12 inches to the rear of the stove). The gap seemed to increase to about 3/8 inch (perhaps from hear expansion) and the "T" connection started to glow red. Shutting off the air and damper did not seem to help right away because the air was getting to the fire thru the gap. With the damper closed I could see glowing inside the pipe thru this gap at the "T" connection.
Did I just overfire the stove? The installer was out last week replacing my chimney cap and he said that as far as creosote goes it looked good with no buildup at the top of the chimney. Is this cause for concern or does a small amount of creosote build up during the slow overnight burns and then burn off next time a hotter fire is burning? Did I over fire the stove with the pallet wood?? Inquiring minds want to know and any comments would be appreciated.
