Yotul GF 400 DV ?
Not that I know of. That unit probably hasn’t been tested with anything other than the OEM refractory panels, & you just can’t be sure that something like tile in there would withstand direct heat from the burner. If it fractures, it could cause possible damage the glass front & that glass isn’t cheap. Many industrial heating suppliers have generic refractory panels, which are made from materials similar to the OEM, & can be cut to fit as needed. I think that would be a safer direction to go.
I'm with DAKSY- Always best to use OEM parts, in case other issues arise that can't be blamed on your modifying something. They are optional, only for aesthetics. My older Sebago gets fresh hi temp black paint when needed.
Reactions: DAKSY
