Chimney Fire in Black Stove Pipe?
southbalto
366
Mid-Atlantic
Is it not common for chimney fires to occur in the connector pipe? I was just wondering if there would be an issue for folks that top vent into a long lets say 10-15' section of single wall before going into a class a cieling support box.
With a top vent straight up shot, if creosote falls down into the stove, it would likely burn there on top of the baffle. That is a much better place to have burning creosote than say a through-the-wall thimble/Tee.
With the Tee, there is a greater chance that creosote will curl, peel, and fall to collect there for a while before an event sets it off. Creosote falling onto the baffle is more likely to be set off sooner and so will not build up to a large event.
This where the double wall is worth a few more bucks for the run before it hits triple. If you do get a fire, it should be able to withstand a fire longer before failure.
greenteam said:
most stoves list the maximum length of connector pipe usually less that 6' or code limits to being a short length. I know of no incidents connector pipe is anywhere near 15'
greenteam said:
from your manual...tHE MAXIMUM VERTICAL RUN OF SINGLE WALL STOVEPIPE SHOULD NOT
EXCEED 10 FT.
The recommended limitation applies to Single Wall stovepipe. I've never heard of a similar limitation on Double Wall. In any case, if you burn proper fuel and operate the appliance the way it's designed to be operated, and properly maintain (clean) the system, you really shouldn't ever have a chimney fire, because your flue will remain relatively free of excessive creosote build-up. Rick
BrotherBart said:
Eh BB. The general thinking is that the angle of repose for creosote is 30° off plumb and as such class A elbows may not exceed 30°. That pic looks to be about 45° and I would not be comfortable with it. I am not stating it as a code requirement, just my personal comfort factor.
LLigetfa said:
"Eh BB. The general thinking is that the angle of repose for creosote is 30° off plumb and as such class A elbows may not exceed 30°. That pic looks to be about 45° and I would not be comfortable with it. I am not stating it as a code requirement, just my personal comfort factor.
I think that long pipe is insane for more reasons than one.
This is mine. It's all single wall up to the support box. 2 45°'s up at the top (had to get around a rafter). I've never had a problem of any kind with this setup. Rick
The big problem I have with the one in the pic I posted is support at those angles. Just looks scary to me.
Agreed...I don't like it much either...for that same reason. Rick
As the air around a vertical pipe heats, it continues to rise upward along the pipe as hot air so the losses diminish. The angled pipe would have greater losses because the hot air would not follow the pipe.
BrotherBart said:
WOW..never seen anything like it!
A lot of people who are trying to "be the most efficient" run their stove pipe like that. look on youtube for videos of it... TONS of them. Of people running through a foot from their ceiling through their house, attach on a couple of magic heats... because the chimney is "where all your heat waste is". So I think people do it on purpose thinking they're doing a good thing.
Hell, my chimney goes straight up, and is only 16' total using 4.5' of double wall in the house (included in the 16')... and I get icicles hanging off my cap when it's cold -.-
If I had some single run like that, my flue gas would be room temp by the time it got outside.
Hass said:
A lot of people who are trying to "be the most efficient" run their stove pipe like that...
Ja, I know it. In the old days we would start with 8" pipe so that we could capture more heat cuz the flue gases moved slower. As the pipe snaked around, we would reduce to 7" using a long taper to keep the velocity up as the gasses cooled, then reduce again to 6" at the thimble. The pipe would hang from eye bolts in the ceiling with snare wire.
I'm planning an install with Selkirk 8"dbl wall black pipe. They recommend not to exceed 20' dbl wall before going into to class "a".
My install was going to be a straight run of 27' dbl wall to cathedral ceiling. Their customer service said that length should be ok on straight run,
provided the pipe was stabalized somewhere in the run.
Same thing jumped out at me. That's a lot of hot pipe not to be supported.
I understand from this post that reducing the diameter of the pipe causes the flu gas to move through the pipe faster. I’m wondering if the possibility of creosote buildup would be less if the chimney was a smaller diameter pipe than the stove pipe?
