Do you recommend that I up the settings ?Well, I doubt they were changed, but you should record them at some point.
From what little we have, it does appear you need more air. That is, black soot, lazy flame.Do you recommend that I up the settings ?
I'm going to assume that the P1 setting is 1730, not 2250.
I went back and checked the P1 settings. After it ran for a bit, the figured settled on 1820. Make sense ?I'm going to assume that the P1 setting is 1730, not 2250.
That precisely how the Monia runs.A good burn should have a nice tight flame, yellowish in color, not orangish. The pellets should dance in the pot, but not fly out. The bits of ash should fly out like fireflies.
At the risk of sounding stupid, what prompts on the keypad do I use to change the settings ? And, what settings would you recommend ?Okay, if you're willing to try, and it's pretty harmless to try, first, I'd read the install manual I gave you a link to.
The important pages start on Page 14. The part about how to use the manometer is on Page 18. The table with all the settings you can change are on P21 for the Sabrina and P22 for the Monia. And, the key parameters you want to try are #18 thru 22, those are the combustion fan speeds for P1 to P5.
Go ahead and adjust the combustion fan speed, see how it affects the flame. Change the speed, wait a bit for things to normalize. You have to try and use your judgement.
Uhm, well that's better than 2250, but doesn't explain why you showed 1730 at first. To be honest, it doesn't really matter.I went back and checked the P1 settings. After it ran for a bit, the figured settled on 1820. Make sense ?
I thought that I first reported 1830 not 1730. No matter.Uhm, well that's better than 2250, but doesn't explain why you showed 1730 at first. To be honest, it doesn't really matter.
When you go into the parameter settings, you'll see what the actual settings are. At THAT point, write down what those settings are, so you can revert, in case you decide to start over.
As I wrote, the process on how to access the parameters is in the programming manual. You want to read it and in particular study the chart on Page 14. You need to drill down the menu to get to Menu Parameters, Setting Factory.At the risk of sounding stupid, what prompts on the keypad do I use to change the settings ? And, what settings would you recommend ?
Ok. I'll try it by eye, but is there a maximum setting that you would recommend not exceeding ?As I wrote, the process on how to access the parameters is in the programming manual. You want to read it and in particular study the chart on Page 14. You need to drill down the menu to get to Menu Parameters, Setting Factory.
On Page 15, they tell you the access code is "E9".
On Page 19, the show you how to drill down to the key settings you want to change, #18 to 22.
As for what settings would I recommend, I can't. I'm not looking at your stove. You have to look at your stove and adjust the fan and see whether that's better or not.
THAT's why I keep recommending the manometer or magnahelic. They take most of the guesswork out. Then you can tweak to the final setting by eye/
No, the stove settings have a range, they won't let you exceed what the mfr deems safe.Ok. I'll try it by eye, but is there a maximum setting that you would recommend not exceeding ?
I can't seem to get past the E9 step. I keep getting the message "code error" ?No, the stove settings have a range, they won't let you exceed what the mfr deems safe.
Start with the first P1 setting which would be Parameter 18.
Ok. I got that. P1 is now showing. What's next ?Are you inputting "E9" at the right point? You should be at Menu Parameters>Settings Factory>Code Access>
Then you scroll until you show E9
You scroll until you get to Parameter 18, that's the one for the combustion fan on P1, so it should show 1830 or so.Ok. I got that. P1 is now showing. What's next ?
I got it Is it ok the increase the blower speed too ?You scroll until you get to Parameter 18, that's the one for the combustion fan on P1, so it should show 1830 or so.
Room blower? You mean Settings 23 to 27? Heck yeah. Did you adjust Parameters 18 to 22 already?I got it Is it ok the increase the blower speed too ?
Yes, settings 23 to 27. I increased them a bit too.Room blower? You mean Settings 23 to 27? Heck yeah. Did you adjust Parameters 18 to 22 already?
Uhm, I dunno, I would keep an eye on the stove. Regular checks. Just make sure the pellets aren't flying out of the pot. The risk is you blow unburnt pellets out, so you don't get all the energy from them.Yes, settings 23 to 27. I increased them a bit too.
I pretty much maxed out the settings for 18 to 22. Is that ok ?
Now, you're an expert, you pretty much know as much as I know, and it seems you know more than your dealer techs.
If it doesn't have an OAK, it sure does.Makes no difference if the other stove is running too.
