mikkeeh said:Thanks..how much do you use?
mikkeeh said:Ive read that powdered graphite helps some. Where would i find some?? (Notice I spelled Harman correctly! )
ironpony said:did you remove the mouse during install??
Harman puts one in the box to eat the bugs
while being shipped over from China.....................
If you have the canned spray graphite (Lowes and HD sell it), you can spray it right into the burnpot - where the auger pushes the pellets out.
referee38 said:Dumb question where do you put the graphite to help the auger
bcb1 said:And the final place to spray graphite is the fines collection box area, on the right side of the stove. Remove the fines box cover, vacuum it out thoroughly, and spray the inside liberally with graphite. (I use whatever lube I have available - graphite, WD-40, silicone spray lube, whatever).
pjonthemount said:bcb1 said:And the final place to spray graphite is the fines collection box area, on the right side of the stove. Remove the fines box cover, vacuum it out thoroughly, and spray the inside liberally with graphite. (I use whatever lube I have available - graphite, WD-40, silicone spray lube, whatever).
Fines collection box??? That's the first time I've heard that term.
I don't remember seeing the subject in the manual.
Where is it located? Could you post a pic?
