If woodstock made a 3.0cf or higher stove that had a front loading door, I'd buy it in a second.(as long as it had a cat)
BeGreen said:A cat stove isn't for everyone, they do require some specific burning constraints and a little additional maintenance. But their real strength is turning out to be steady heat output which is not often touted as their best feature. This, together with long clean burns at low settings is enough to keep me interested. But the BlazeKing would never make it passed my wife into our livingroom and I'm unlikely to own a VC stove anytime soon.
EasyEd said:I wish there were other large cat options (hello Woodstock!), but it seems the BK is exactly what I'm looking for.
Southland said:EasyEd said:I wish there were other large cat options (hello Woodstock!), but it seems the BK is exactly what I'm looking for.
Check out the Buck Model 91 stove. It's a catalytic stove and has a 4.4 cu ft firebox. My parents have been using the insert version for 8-9 yrs and it has been an outstanding stove.
http://www.buckstove.com/wood/model91.html
Woodford said:Rockey said:I am leaning towrads replacing the NC30 with a large catalytic that will hopefully be as easy to operate as my cat insert and give me a longer burn time.
Let me know if you decide to sell your Englander, I might be interested.
I doubt that I live very far from you.
TheFlame said:BeGreen said:The article is a bit dated. True, improvements in stove design have produced non-cat stoves that burn almost or as clean as a cat stove. However, the few remaining cat stove mfgs. have ironed out most of the bugs and newer catalysts seem to stand up longer.
Dated? He totally poo-poos the esteemed Woodstock Fireview, known world-wide (or at least within the domain of hearth.com) as the gold standard for catalytic wood stoves!
In any case, I love the part where "Todd", who owned both a Hearthstone Homestead and a Fireview, objectively states that the Fireview is a better stove and produces more heat with less wood. Then Tom goes on to state, "I'm not a big fan of some of the numbers manufacturer's toss around either, specifically heating area and burn time per load of fuel, which I feel are more than a trifle subjective and might get a bit exaggerated by overzealous marketing departments at times." After which he uses an entire page of numbers to refute Todd's claim that the Fireview is a better stove. Classic hypocrisy. I value the objective opinion of somebody who has burned both stoves over a bunch of calculated numbers as to why one is "better" than the other.
While I don't want to beat up Tom too much unless he's present, when I stumbled on that page quite some time ago I always thought it was very slanted towards what Tom sells (non-catalytic stoves), and I always wanted to get the opinions of others on it.
My esperience with my Oslo is that even though it is a really great heater, it reacts in exactly the way described in the original post. The heat output curve is very peaky, and I am fiddling with it alot. I still love it, but the catalytics actually seem like easier operation to me, it sounds like once you get the cat lit off you can do no wrong, whereas with a burn tube stove you could have the secondary burn stall if things aren't quite perfect, and then from there you got black glass and no heat.
As stated here, really the ONLY basic difference between cat start up and non-cat is daleeper says, you have to lift the bypass lever. And as Be Green says they can be polluted from burning stuff aside from reasonable dry untreated wood. I quickly learned how to wait until the stove temp was hot enough and then lift the bypass arm (and no muscle strains from that yet :cheese: ) and I really only tend to burn dry firewood anyway. My cat costs about $30 per year considering my stove runs non stop from mid Oct to early May and I replace it about once every four years and it takes about 15 minutes to replace. Because of the slow thorough burn the smaller firebox is not as much of an issue as it might be in a secondary stove. All said, it is a matter of preference but you will seldom read a post from a disgruntled cat owner on this forum and I've never read one from a Woodstock owner except for Tom.daleeper said:BeGreen said:A cat stove isn't for everyone, they do require some specific burning constraints and a little additional maintenance. But their real strength is turning out to be steady heat output which is not often touted as their best feature. This, together with long clean burns at low settings is enough to keep me interested. But the BlazeKing would never make it passed my wife into our livingroom and I'm unlikely to own a VC stove anytime soon.
To start with I think that the argument between cat and non-cat sometimes leave out the fact some want to burn hot, some want long low burns. I do not think that a non-cat can possibly win in the long low burn department, if both types were set up for their most ideal burning conditions. Now, I have always believed the suggestion that the non-cat could possibly win in the high output side, yet there seem to be a real high number of Blaze King stove users represented here on the north side of the US/Canadian boarder. I don't care which one wins the high burn, because my stove room is too small to take advantage of a big stove running real hot. I want long slow burns. A person wanting real hot burns are going to be feeding either stove a lot of wood.
What I do see argued here is that the cat requires specific burning constraints, and leave out the fact that the non-cats have very similar constraints. I have read several of the new stove manual burn procedures for both style stoves. All require opening the primary air up to start a burn from cold for a period of time (till the wood is charring) and then shut down slowly to the desired burn/heat rate. The only difference is on a cat stove, the bypass damper needs shifted also. All precautions for using dry wood are the same. From viewing problems here on the forum, I can't see that the cat maintenance and repair is a whole lot different than non-cat either, though this will bring strong argument from the non-cat crowd. If both stoves are run properly, neither will take much in the way of maintenance. If burned improperly, either stove can be damaged beyond repair.
D/F said:I'm in the market for a new stove...I need to heat a 1700 square feet, poorly insulated split level house...
I was just thinking about maybe a cat stove...I wonder if the blaze king would cook me out of here. We rarley get below 20 degrees in the winter. We usually hang out at around 35
Rockey said:Southland said:EasyEd said:I wish there were other large cat options (hello Woodstock!), but it seems the BK is exactly what I'm looking for.
Excellent point about the Buck 91. A huge firebox and catalytic, the only drawback looks like an 8" flue. Is this a stove or insert? They call it a stove but only show a picture of it as an insert.
Highbeam said:Lots of BKs have been installed in the pacific NW. The beauty is the LOW and slow burning which will prevent you from being cooked out. A guy could seriously oversize a cat stove and be OK since you can actually turn it down. If you oversize a non-cat you will be cooked out since there is a minimum setting on these stoves that is hot.
The smaller princess BK would be fine and is a relatively decent looking stove. The woodstock is probably cheaper and is very attractive.
Wet1 said:Semipro said:Wow, if stovepipe temps in some cat stoves are really that hot (and clean) it seems like some sort of heat exchanger right after the stove could really extract some more heat from the flue gases without causing other problems (creosote formation, poor drafting).
I would assume the 1500° temps seen are at the cat itself and not the gases further downstream (up the flue) after the cat. Regardless, much of this heat is transfered to the stove housing around the cat.
