Since I did the install of my pellet stove myself, I'm a bit concerned about CO2 and smoke leaks from the joins in my pipes. Is there anyway to check this other than visually?
No, you won't....CO has no odor. Get a CO detectorsawdustburners said:you'll smell it
ylomnstr said:Since I did the install of my pellet stove myself, I'm a bit concerned about CO2 and smoke leaks from the joins in my pipes. Is there anyway to check this other than visually?
Some of them are both. My Kidde's are hardwired (with battery backup) and do both CO and smoke detection. You can get one unit that does both - in the old days that wasn't the case.hossthehermit said:Kidde makes one of cheapest AND best rated on the market, looks like a smoke detector. IT'S NOT You need both.
DiggerJim said:Some of them are both. My Kidde's are hardwired (with battery backup) and do both CO and smoke detection. You can get one unit that does both - in the old days that wasn't the case.hossthehermit said:Kidde makes one of cheapest AND best rated on the market, looks like a smoke detector. IT'S NOT You need both.
Here's a battery version: http://www.lowes.com/lowes/lkn?action=productDetail&productId=143036-65213-21006674&lpage=none
AC/Battery version: http://www.lowes.com/lowes/lkn?action=productDetail&productId=62843-65213-KN-COSM-IB&lpage=none
GotzTheHotz said:Get a fire ex too, this also does not go by the stove but by a doorway to the room the stove is in
macman said:GotzTheHotz said:Get a fire ex too, this also does not go by the stove but by a doorway to the room the stove is in
Fire ex???????? Not sure what that is.
Smoke alarms are good as long as they test okay. CO detectors use a different technology (usually electrochemical) to sense CO and that has a lifespan. Some have removable sensors which you replace every couple of years (check the manual). Others (like the Kiddes) have you replace the whole unit on a less frequent basis - the Kidde is replaced every 7 years.n3pro said:Reading the post question brought up another question. All my smoke alarms are the wired in type and are original (1995) - except batteries of course but with the other post about 5-7 year life span (somehow I didn't know) would it be a good idea to replace all mine (bedrooms, foyer, top of steps) with the combo or is that overkill; just the hallways and replace the bedrooms with smoke only?
ylomnstr said:This is the stuff I got from home depot. Should work:
http://www.covalenceadhesives.com/SearchProductsDetails.aspx?ID=77
macman said:ylomnstr said:This is the stuff I got from home depot. Should work:
Did you get that in the plumbing dept. or the insulation dept? The specs look like it's for taping insulation, not heat pipe (200 degree temp limit).
The stuff that I think Woodsman is talking about is the tape that's used to seal pipe joints, like on an oil burner exhaust pipe.
I think you need something that will handle more than 200 degrees.
