    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    That would be the Portal to Hell . . . ;) :)
    As mentioned there is also the lazy Northern Lights (aka Ghost Flames) which either flicker in and out or just kind of dance lazily at the top of the firebox and the BBQ Gas Grill Effect of blue jets of flame shooting out the secondary burn tubes.
    Seeing no smoke out of the chimney as you mentioned is also a good sign.
    Helpful Sponsor Ads!
  2. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    Well stated . . .
    Also, before I forget, I prefer Condar thermos . . . got a magnetic mount on the stove and a probe style for my double wall pipe . . . I know the magnetic Condar was spot on with temp when compared to the IR gun . . . maybe 25-50 degrees difference.
    The thing with any thermo though is to treat it more like a gauge vs. an absolute . . . you know . . . your car registers half a tank of gas . . . it doesn't show that you have 9.3 gallons of fuel . . . but your speedometer registers the exact speed (well maybe not calibrated . . . but you get the point) . . . in the same way I approach the temps on my thermos as giving me a general idea or guideline as to where my temps are . . . in other words . . . I wouldn't trust them and their readings if I was making a souffle and temps were critical.
  3. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    That would work . . . just don't stuff it to the gills as mentioned earlier . . . and save some for later use . . . great kindling . . . or for use with marginal semi-seasoned wood.
  4. stoveguy2esw Minister of Fire
    madison hgts. va
    i mean a "relatively" quick hot fire, starting with kindling as normal but instead of loading big long burning logs would load smaller splits which will burn up a bit quicker but we wouldnt be looking at a massively hotter fire just a sprint fire to heat the stove and the stove would then heat up the room some but not run you outta there
  5. Battenkiller Minister of Fire
    Well, the souffle makers of the world are numerous, so they must make decent thermometers for them to use. I just think it's too bad they won't come out with a good one for stoves (never used the Condars, maybe they are good), how hard could it be? I'd pay $50 for an accurate one, but I guess the demand at that price would not be that great in general. Seems to be quite a demand for $50 IR thermos just looking at the marketplace, though.
  6. Loco Gringo Feeling the Heat
    Western North Carolina
  7. cptoneleg Minister of Fire
    Virginia
    Do exactly that, usually with this weather, evening fire her up, mornings fire her up, burn down . nice and warm
    Yours Truely,
    Firewood Scientist
  8. Battenkiller Minister of Fire
    The comment was directed at Mike Houlton of Englander stoves, and it was meant in earnest. I have no idea why you played with the quotation boxes to make it look otherwise, but that ain't cool, dude. :mad:
    As far as defending BB against any barbs, I think the guy is quite capable of that himself without your help.
  9. Loco Gringo Feeling the Heat
    Just getting to the point is all. No harm no foul.
  10. Chrism Feeling the Heat
    Eastern PA
    Well had the stove goin brought it up to temp according the stove top thermometer 400 was good no smoke comin out of the chimney and nice and warm!! That stove top thermometer made it a lot easier !! Thanks
  11. oldspark Minister of Fire
    North West Iowa
    Once you get used to the stove you can throw the thermometer away but they are still fun to watch, I like shiny objects any way.
  12. Battenkiller Minister of Fire
    I've found that shiny objects are the best way to get my wife up to temperature as well. %-P
  13. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    I still find it is useful to have the thermo around . . . while one can get used to what to expect and the corresponding temps, once in a while things can be a bit wonky and you can get fooled . . . I know I've been fooled before by seeing a fire and expecting it to be a lot less hot than it was in actuality . . . and vice versa.
  14. Chrism Feeling the Heat
    Eastern PA
    Yeah jake I realized that last night lol
