Harman P35i stove settings question
belam Posted By belam, Dec 20, 2010 at 11:55 PM
Thread Status:
  1. belam
    belam
    New Member 2.
    NULL
    Oct 12, 2010
    9
    0
    Loc:
    Maryland
    Just got a Harman P35i pellet stove...loving it so far. Just had a question regarding what setting most people use on weekdays during the day (nobody's home). Do you turn the temp way down and then blast when you get home or just try too keep a steady comfortable temp all day? I'm assuming you save on pellets if you turn the temp down during the day, but I'm new to this so I figured I'd ask the experts.
    Thanks,
    Brian
  2. imacman
    imacman
    Guest 2.
    NULL
    Go back and edit your thread title to include the Make & Model of the stove....you'll get more replies
  3. Mike16W
    Mike16W
    New Member 2.
    NULL
    Jun 21, 2011
    22
    0
    Loc:
    New Mexico
    Did you every find the best settings for the Harman P35i stove. I have just installed one and am trying to get familiar with it.
  4. DAKSY
    DAKSY
    Patriot Guard Rider Moderator 2.
    NULL
    Staff Member
    Dec 2, 2008
    6,652
    1,200
    Loc:
    Averill Park, NY, on Burden Lake II...
    Every house/install is different. What works for house A may be
    totally inappropriate in house B.
    Set your unit to a feed of 3 - 3.5 & leave it there.
    Run it in "Room Temp" mode for awhile with a setting of 68 - 70.
    See if you like the performance. If you (or the wife-GF-SO)
    is unhappy, make an adjustment one way or the other.
    Then try it on "Stove Temp" mode & leave it alone for a couple of days.
    See if you're more comfortable in that mode.
    Only THEN can you decide which way the performance works best in
    your particular install.
    There are those of us that run HARMANS BOTH ways.
    I'll run in room temp from now til maybe Thanksgiving & then switch to
    stove temp for a more even heat. I leave it that way until March, when
    the weather starts to break & then switch back to room temp til I shut
    er down for the season.
  5. Mike16W
    Mike16W
    New Member 2.
    NULL
    Jun 21, 2011
    22
    0
    Loc:
    New Mexico
    Thanks for the quick reply. I have read here that people recommend putting the feed rate between 4 - 5. I understand that it is a limiter on the max feed rate but I do not have the experience with this stove to notice any difference. Have you experimented with this setting?
  6. DAKSY
    DAKSY
    NULL
    Staff Member
    Dec 2, 2008
    6,652
    1,200
    Loc:
    I leave the feed at 3.5 The only time I move that particular
    dial is when I'm doing my "One Ton" maintenance.
    At that time I turn it to "Test" so that the combustion blower
    exhausts the unit & keeps the dust from spreading thru our kitchen...
    You may have better results with the higher setting, maybe not.
    When I sold Harmans, I told buyers that they were going to have
    to learn to "BOND" with their new unit, until such a time as they
    got to know what worked best for them. Once they've established
    that bond, they just had to keep their unit clean & it would keep
    them happy.
    Good luck with yours!
  7. lbcynya
    lbcynya
    Feeling the Heat 2.
    NULL
    Oct 26, 2006
    480
    62
    Loc:
    W Michigan
    Feed rate is simply used to prevent not completely burned pellets from spilling out of the burn pot. Since pellet fuel can wildly vary (wood species, density, moisture, length, etc), 3.5 is safe, but it might limit your stoves ability to produce maximum output during peak demand periods...like 20 below zero outside... The manual tells you how to determine max setting for the type of pellet you are using now and they also suggest you repeat the process if you change pellets due to the factors I mentioned above.
    In stove temp Harman's are controlled 100% by the ESP. In stove temp the temp dial simply corresponds to a temperature value for the ESP. So a temp setting of 5 might correspond to 400 degrees on the ESP. The stove will speed up or slow down feed to insure the ESP sees +/- 400 degrees flue gas temp. If you set your feed rate to 2, then the ESP might not see anything above 325 degrees since there isn't enough fuel and you'll never get the heat output you are requesting. On the other side, if you set your feed to 5 the stove feed rate may never go above 3.5 since 3.5 is sufficient to achieve the 400 degree requirement.
    Room temp works the same way, but now 2 variables are controlled to achieve the proper heat setting, the room sensor (primary) and the ESP.
    Higher feed rates = quicker response and more fuel to hit the requested target. Too high of a feed rate = not completely burned pellets spilling over the edge. You don't have to stay awake watching, just keep the burning pellet line about an inch from the edge on the coldest days and inspect your ash bin while cleaning to determine whether you see wasted fuel.
    Feed rate is the most commonly misunderstood settings on Harman's...
    PS - I use a Harman diagnostic tool, so the information above is based on facts as I've lived them. :)
  8. Mike16W
    Mike16W
    New Member 2.
    NULL
    Jun 21, 2011
    22
    0
    Loc:
    New Mexico
    Bob,
    Thanks for the information. I will have to do some more bonding with my unit. I'm not quite sure what I am looking for if the pellet feed rate is to high or to low and what would be the ideal setting for the feed.
    Mike
  9. lbcynya
    lbcynya
    Feeling the Heat 2.
    NULL
    Oct 26, 2006
    480
    62
    Loc:
    W Michigan
    I think we posted at the same time. See above. :)
  10. badabing
    badabing
    Member 2.
    NULL
    Sep 20, 2011
    15
    0
    Loc:
    NH
    I also just had a P35i installed. The installer also does maintenance and repairs on the units. He set the feed rate at 3.5 and told me to leave it there. Everything else he explained relative to the insert has been right on. Others have made some good points about getting to know the stove and after more use the feed rate might have to be adjusted slightly, but for now I would stay with 3.5.
    David
  11. Mike16W
    Mike16W
    New Member 2.
    NULL
    Jun 21, 2011
    22
    0
    Loc:
    New Mexico
    Thanks David,
    I have had the feed rate higher, but will now try it at 3.5.
    Mike
  12. lbcynya
    lbcynya
    Feeling the Heat 2.
    NULL
    Oct 26, 2006
    480
    62
    Loc:
    W Michigan
    If your higher feed rates didn't cause any spilling or possible spilling, no reason to lower it. Higher feed rates will allow your stove to "do its job" better.
    As said above 3.5 is safe. I've found 4.5 to be better. Installers will always play it conservative to insure customers don't run into any problems that, in turn, gets lumped back on the installer...also known as self preservation. If 3.5 was in fact the "golden rule" then we wouldn't have an adjustment knob and they'd just make it another dip switch the consumer won't find, easily.
    If you want to be safe, do what they say and set it and forget it at 3.5. If you're like me and you want give your stove the best chance to do its job, set it higher and watch for signs of overfeeding. Either way, nothing "bad" will happen.
    Also, keep in mind that each numerical value on the feed rate represents feeding time in any 60 second increment. So a feed rate of 1 will only allow the stove to feed pellets for 10 seconds. Feed rate of 5 will allow the stove to feed for UP TO 50 seconds in any given minute. So the difference between 3.5 and 4 is five seconds per minute. :)
  13. Mike16W
    Mike16W
    New Member 2.
    NULL
    Jun 21, 2011
    22
    0
    Loc:
    New Mexico
    Thanks for the insight. I have been setting my feed rate at 4.5 also and have not had any issues with unburnt pellets being pushed over the edge. I will monitor it when I switch pellets.
    Thanks
    Mike
Thread Status:
