Harman Temp probe?
canuck_22
259
Ontario, Canada
What do we know if the Harman temp probe exceeds 25 feet? Is there an official Harman explanation?
You can extend it farther...
From the P68 manual:
The room sensor is a small temperature sensor on the
end of a 60" wire. This sensor is installed much like a
standard wall thermostat. Because it is so small, it can
be hidden along the trim of a doorway or even up the
leg of a coffee table. There is a remote room sensor port
on the rear of the unit for easy external connection. Use
standard 18-2 thermostat wire to extend the distance to
the desired location (50' maximum).
I read that too...but right under that paragraph in the book it says...
NOTE: Distances of more than 25 feet from the unit or in another room are not recommended.
Dont we just love this kind of clarity!!...grrrrr.
Up the gauge of wire. 18-2 is to light of gauge for that far of run, so go to 16-2
Ahhh...but again Harman calls for 18-2 up to 50ft !! (page 5 of the P61A manual)
Right hand not communicating with left:oops: Be easier if they just made a simple wireless system for these situations. Couple batteries would last a season to talk to stove without any wires like the outside sensor we use for the indoor outdoor temp gauge.
I would say this is what they got during their teasing phase and the results dropped off a few feet past the recommended distance
Another clause would be that they are supposed to be room heaters and 50 feet is one big room.
May I ask why would one want to extend the temp sensor to such extreme lengths?
When you use a programable thermostat
