kenny chaos said:I'll take that as a NO. Nobody here has used one of these.
Geez, get over all your speculations.
karl said:I'm not sure I buy this cooling the stack temperature will cause creosote. I hope Craig, Corey, and some of the other experts chime in on this.
In order to get creosote in your chimney, you have to have wood gases/particulate flowing through the chimney. Then the chimney has to cool enough to let this stuff condense on the walls. I think you guys are too concerned about the temperature.
I have read posts on here where catlytic stoves have stack temperatures as low as 150 degrees. Thats pretty cold but they don't fill up with creostoe because there isn't anything in the exhaust to form creosote.
I would think that as long as your stove is hot enough for the polution control device(Cat or burn tubes) to activate, then the only need for a warm exhaust is to create a draft.
Does this make sense?
wolfkiller said:Kinda testy hu? Let us know if you give it a try I am looking for hot water solutions as well.
kenny chaos said:Has anybody used one of these?
http://www.fluemiser.com/
[/quote]quote author="jdemaris" date="1232350384
I've had them around the stack, and inside the furnace. At present, I have one loop of 1/2" pipe that runs through the firebox of my wood-furnace, hooked thermosiphon to an 80 gallon storage tank. Only problem I have is in exteme cold weather - when the fire burns full bore day and night. It makes too much hot water, and if we don't use it, the TP valve keeps blowing off (which is pipe to the outdoors).
awoodman said:[
What type of 1/2'' pipe did you use ( stainless ,copper) and do you have pics. This is what I want to do with an old 40 gal. tank.
Do you have any pic's of your insatlljdemaris said:awoodman said:[
The several that I've made that ran around the smoke pipe were from flexible 1/2" copper pipe. Flexible 1/2" water pipe can be bought at any plumbing supply; just costs a little more than rigid copper type L, K. or M pipe. Never had a problem with it. You can easily spiral it upwards around the pipe like a snake with no seams.
With pipes inside the firebox, I won't use anything but stainless. 1/2" black pipe will work for years, but if you ever get a problem with air bubbles/pockets in the pipe during a hot fire, the black pipe can burn out.
A good thermosiphon systems ought to have a few safeguards. A backflow check-valve at the bottom of the coil, a air-bleed at the top, and a TP valve in the top of the coil itself, along with the TP valve in the storage tank. Any old electric hot-water will work fine as a storage tank with no modifications needed.
One word of warning. If you plan to hook the storage tank into a second, fuel-fired heater - remember one thing. If feeding into a gas or LP heater, you must install a tempering valve. That, because gas hot water heaters have internal thermal fuses that will blow if incoming water is too hot.
You can only use thermosiphon if you mount the storage tank avove the coils. Only photos of a thermosiphon system is the one I'm using now - that is hooked to a firebox loop in my furnace. If you want to see that, ask, and I'll post. You can go to any of these links though and download installation manuals for factory made coils and thermosiphon. The factory made stainless loops or coils all cost around $150-$200. The Hot Rod can be made to fit just about any woodstove. Let me add, I'm not trying to sell a product. I made many homemade rigs that may of not looked great, but worked fine. My first house that I owned was heating 100% with a double-barrel, home-made wood-furnace - made from old 55 gallon steel drums. Heated our large farmhouse and also all our hot water for 10 years. It looked awful, but worked fine.
Hilkoil
http://www.hilkoil.com/product.htm
Hot Rod
http://www.yukon-eagle.com/Portals/0/manuals/Hot Rod Manual (Revised).pdf
Heem said:FWIW, my insurance company has stated in no uncertain terms that they will not cover any damages caused by using a wood burning appliance to heat domestic hot water.
smokinj said:Do you have any pic's of your insatll
jdemaris said:You can only use thermosiphon if you mount the storage tank avove the coils. Only photos of a thermosiphon system is the one I'm using now - that is hooked to a firebox loop in my furnace. If you want to see that, ask, and I'll post.
