FLUE LINER AND CHIMNEY
WALL.
• tHE FIRECLAY FLUE LINER MUST HAVE A NOMINAL SIZE OF 8” x 8”, AND
SHOULD NOT BE LARGER THAN 8” x 12”. iF A ROUND FIRECLAY LINER IS
TO BE USED IT MUST HAVE A MINIMUM INSIDE DIAMETER OF 6”
(157MM) AND NOT LARGER THAN 8”
I told ya how to fix that Summit, did you read my PM? Sorry, Hijacked another thread, carry on......oldspark said:I agree with Todd, if the smaller splits burnt well with the break in fires you might just need some one on one time with the stove. I had problems running my summit (still do) but my wood and flue are fine.Todd said:I think you just need a little more time figuring out your stove before you make any big changes to your install. You said your breakin fires went well with smaller wood so try building up the fire from there and don't use larger splits til you have a good coal bed established. An outside clay tile chimney will take a little while to warm up to get the draft going so smaller splits will help that along.
SKIN052 said:The fact that he has a whole story of cold chimney underneath his set up really throws me off, is this normal?
You cant fix stupid! Yes I read your PM, stove still has me thinking it has a mind of its own at times.SKIN052 said:I told ya how to fix that Summit, did you read my PM? Sorry, Hijacked another thread, carry on......oldspark said:I agree with Todd, if the smaller splits burnt well with the break in fires you might just need some one on one time with the stove. I had problems running my summit (still do) but my wood and flue are fine.Todd said:I think you just need a little more time figuring out your stove before you make any big changes to your install. You said your breakin fires went well with smaller wood so try building up the fire from there and don't use larger splits til you have a good coal bed established. An outside clay tile chimney will take a little while to warm up to get the draft going so smaller splits will help that along.
I think KoKo is at the bare minmum with regards to hight and chimney set up. Extened it slightly and lining it with 6" would help allot I am sure of it. The fact that he has a whole story of cold chimney underneath his set up really throws me off, is this normal?
Yes that does sound like a draft issue.Koko said:Update...
Maybe my wife is better at the stove than me? Still having issues, but she does have the temp up to 450 degrees. Only problem is when she shuts the door the fire just dies down. It burns, but not properly at all. The wood is catching quickly off the coals. Right now I'm leaning towards draft versus wood, but that's me. Hopefully grabbing a MM today after work.
Skier76 said:LMAO! I'm hoping there's a "cractling fire app". So I can mount it on the wall in our bedroom in CT...and we can have that nice Jotul glow. It just won't be as toasty.
SKIN052 said:Skier76 said:LMAO! I'm hoping there's a "cractling fire app". So I can mount it on the wall in our bedroom in CT...and we can have that nice Jotul glow. It just won't be as toasty.
Here it is, Fireplace HD
http://itunes.apple.com/us/app/fireplace-hd/id364188191?mt=8
Fireside HD provides a fire so lifelike and captivating, you will feel the heat on your face and smell the dark smoky scent of the hearth. Fireplace HD is a spectacular display of cinema quality high definition video for your iPad. It features a crackling woodburning fire so realistic you'll get hot!
