I have the Progress Hybrid and absolutely love it. But I wish I had room for a second stove. If so I would get the IS in a heart beat. You simply can't go wrong with either one. And the IS is a super bargain to boot.Price was the biggest issue. I personally believe the Ideal is a lot more bang for the buck. The progress looks better and has a higher btu output, but the Ideal is more controllable, has a bigger box, front loading, and I believe it will burn longer. They took the technology they learned from the Progress and improved it in the Ideal.
I honestly think they are similar enough that you should pick what you can afford and looks good to you.
Probably. The Max btu output is what I was referring to. Basically, meaning if it is -10 degrees outside and you need maximum output the PH has more full throttle reserve. Believe me when you put the Ideal Steel on a maximum burn it will run you out of the room too.
Good deal. Here's a little teaser. As you can see there is plenty of fuel left in there. This is what I come home to everyday 11 hours after I reloaded and set. The floor is about 4" below the opening so this guy would love to keep on going, but it will be under 10 degrees tonight so I need to burn her down and heat it up a bit.
If you were in Hawaii this winter, you would wish you had a wood stove!
Woodstock is very conservative in their statements about BTU. If they list BTU output for a stove, you can count on that output. The PH will definitely put out about 11% more heat than the IS when both are asked for high output. In MD that likely does not matter for you. In my climate, that makes a huge difference.
Woodstock is a great company that makes a fine product, and I am sure you will be happy for many years to come. Enjoy, and looking forward to subsequent photos of install and burns....
On a load of 4 or 5 splits of good dry oak and hickory my PH will always have a coal bed capable of reloading on after 14 - 15 hours. To date I have tested it out to 16 hours with no problem. The stove temp will be under 200* but there will be coals for reloading. The IS will probably be capable of going even longer. However, I usually reload after 11 - 12 hours because that fits into my schedule better.I'm considering re-doing my heating setup. Besides the original woodstove in the house I've bought 2 new wood stoves, and trying out a pellet stove this winter too. The wood stoves are both insufficient at heating my house for both the coldest days and also for the duration of my workday. This hasn't really been an issue since my wife kept the stoves going when I was at work. But we are ending our marriage and literally days from being on my own with the stove. I'm really getting nervous about the woodburning situation and thinking a need some bigger and longer burning stoves.
I'm thinking about either a BK or IS/PH. I don't really care for the looks of BK or the IS, but IS definitely has the bang for the buck. But I'm still concerned that only a BK will give me the run time I need. Your 11hr pics are probably a little better than what I have now with either my Rockland or Shelburne, but any chance I can get a 14-15 hr burn out of an IS? And reliably, like every day. I could go without much heat the last couple hours, but I want a good hot coal bed. When I'm on nights and get home at 7am I want to load and go to bed, not fiddle with starting a stove from paper and kindling. So curious if there is any chance the IS (or PH) could be considered, or should I just scratch it off the list?
I believe I read on the other site about one of the IS beta testers doing a test burn of pallet oak with a full firebox and getting 24+ hours.Tenn Dave said it well. It will go a long time before it burns the coals down. If you want 24 hours of usable heat that's a stretch but I believe it's possible. If I loaded this thing full to the gills with good dry hardwood and gently closed the air the whole way I'm not sure what it would do. I'll find out this spring. 14-16 hours is no problem with quality firewood.
One aspect that a lot of people forget is that this stove does have an automatic air feed to the cat. Meaning it can compensate for temperature swings. It is a bimettalic strip. They have been known to flutter on start up, but Woodstock quickly addressed it and sent out a new valve. Obviously this is not a temperature control thermostat like Blaze King, but it does aid in the stoves performance.
Does the PH have tertiary air?I believe I read on the other site about one of the IS beta testers doing a test burn of pallet oak with a full firebox and getting 24+ hours.
