Gooserider
Mod Emeritus
Can the Ryobi operate vertically? How does it drive the wedge - is it hydraulic or some sort of screw drive?
Gooserider
Gooserider
Mr_Super-Hunky said:I would'nt mind using that Ryobi if it did the job relatively quickly. The only problem is that I am buying a stove that takes up to 24'' logs and the Ryobi can only do 18- 20 tops.. I don't want any wasted log space inside the stove so I will have to get or make something that will handle a 24'' log.
I've seen a 12 ton hydraulic splitter that handles 24'' logs but it hooked up to an air compressor rather than using a gas engine or an electric one.
You would have to supply the air compressor (many already have one), and you get a 12 ton splitter that handles large log lenghts for under $350.00. Here is a link to the place www.logsplitter.com
Has anyone used one of these before?
Mr_Super-Hunky said:The only problem is that I am buying a stove that takes up to 24'' logs and the Ryobi can only do 18- 20 tops.. I don't want any wasted log space inside the stove so I will have to get or make something that will handle a 24'' log.
N1ST said:Ok, GooseRider has me worried as I'm close to getting wood for a PE Spectrum which is spec'd at 18" max but I don't have yet. Can someone please tell me what length it can actually hold?
