how much chimney would the princess ideally require?A BK requires more chimney height due to needing more draft from lower exhaust temps, also needs insulated pipe so it stays warm and has proper draft.
You can add more pipe outside with proper bracing, but you do meet the minimum for the stove you are looking at. That would have more than likely caused issues with the BK and having smoke roll out the door during reloads.
Yeah. I have the Osburn 1600i (2019 cousin of the Drolet) on a 24' external chimney and it drafts very well. In fact it could probably use a key damper. I manage this by not stuffing it to the gills when it's super cold out and just reload a tad bit earlier. They are good stoves for shorter chimney runs. At 7,000 ft though you'll absolutely need more than 12'.I had existing 13' of pipe when I installed my escape 1800. After reading through this post ( link below) I felt my draft was low so I added a 2' section to the top. Seems better. Others with 20'+ of pipe are getting STRONG drafting from the Drolet 1800.
Lots of info here
Dialing in the Drolet Escape (1500, 1800 and inserts)
The great value of these two stoves means lots have been sold. The intent of this tread is to help owners figure out the best/ most efficient way to run their stoves or inserts. I think the simple design is great but I am wondering if the easy breathing nature of this design results in an over...www.hearth.com
Also a tighter sealed house will make drafting more difficult.
OP also has an offset that will lower the theoretical height. I would try it with what you have, add height if needed.The Drolet is an easy breather. It is a good choice here. Here is an elevation chart from Regency. They also makes some easy breathing stoves.
I was just showing my wife last night the stoves and that is her favorite one, the myriad 3 , she likes it and will likely be the one we order.You won't have any issues with the 1800. I would suggest an outside air kit, it will help your draft, especially if the house is tight. I love my myriad, really burns great. I use just over 3 cords here in MN burning almost constantly.
I could just add pipe if needed later to the top of existing setup. and the supports as wellOP also has an offset that will lower the theoretical height. I would try it with what you have, add height if needed.
I understand, and am planning on it actually, another thing we leave 2 windows cracked about 2”Not to be a debbie downer but a 12' chimney at 7,000 ft with an offset is just not going to be enough chimney. If by some miracle out works take the W but I'd budget and plan on extending it at least 3 feet. Just know you may need even more.
I’ll look into the side shielding, it does come with a blower. 100cfm, If I decide to get the 1800 I will get the blower for it as well.I don't think the myriad has side shielding, so it will need large side clearances. All of the info is available on the drolet site. You can even download the manual, I believe. These side clearances may or may not be a problem.
I would highly recommend that you get the blower for that stove. You will need it to keep your flue temps in check in the early stages of a fire. We got a thermodisc with our legend too. It didn't take very long and that become unused. We turn off the blower as soon as the fire is starting to "cruise".
My wife likes the pedestal look is why the myriad, over the legend, personally I like this size , legend or myriad.I think it has a 20" side clearance. Based on the little I know, I would want to exceed that.
It has a big enough firebox that loading is not a tetrus affair.
Once you load N/S I doubt you will never want to be restricted to E/W again.
And you can load E/W in a large stove near the back of the firebox for a small load long-burn. I cut most of our wood too long for E/W tho...lots of it 20". 16" is better for E/W in this firebox.
Our legend just idles along with secondaries going for several hours on a small load. With a large load we can go out all day when it's -30C and come home to a bed of coals and a house that is warm enough to get warmed up really quick.
We burn slow-grown aspen and pine. A 10" pine around here is over 50 years old, so it's pretty dense. Sadly, they have all been killed by the beetles. It makes ready-to-burn wood, but is sad nonetheless. Our forest is not the same.
You might be able to mount a pedestal on a legend, idk. I priced out mounting legs on an 1800 (I think it was) and it wasn't ridiculous. We like the look of the legs, so I was checking that scenario out with a couple of stoves that didn't offer legs.
Oh, and consider getting the firescreen. We use ours quite a bit for burning down a big coal bed while allowing lots of heat into the house. I'd say we use it for about 1 out of every 4 or 5 fires or so for this purpose.
I wouldn't replace a good chimney whatsoever. Why?
