    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. MommyOf4 Feeling the Heat
    Southern MD
    Can you please tell me if this is a big issue? I've had so many issues with our contractors that I am about to burst.
    #1
    Helpful Sponsor Ads!
  2. MommyOf4 Feeling the Heat
    Southern MD
    Last night it was flush against the wall. If we drill it in I'm afraid the pipe might bend a bit.
  3. imacman Minister of Fire
    Looks like the pipe wasn't in the correct location to begin with, and finally pulled the screws out. Can't really see, but did they even use drywall anchors??? I hope they didn't just screw into the drywall and say that's good.....:eek:
    Since the pipe pulled the screws out, the stove might need to be pushed back toward the wall another 3/4".
    BTW, can you take some pics of the whole interior pipe set-up and post it? You may not even need that bracket.
  4. MommyOf4 Feeling the Heat
    Southern MD
    :( No anchors into the drywall.
      File size:
      1.5 MB
      124
  5. jtakeman Minister of Fire
    Northwestern CT.
    Looks like they just used Drywall or sheet metal screws(had to use the magnifier bear sent me). You will need to get some type of wall anchor to fix it propperly! Molleys or Toggle will do.
    I doubt you'll break the pipe, But you could break one of the silicon seals on the joints(more like create a leak) So have some goop handy JIC it does leak. Smear some goop(hi temp sealer) over the seam and you should be good to go!
  6. MommyOf4 Feeling the Heat
    Southern MD
    Should I not use my stove until it's fixed?
  7. imacman Minister of Fire
    If you don't smell any smoke, you should be OK. IMO, you don't need that bracket anyway.
    One more question....did the installers use an appliance adapter on the back of the stove? If you don't know or aren't sure, take a close-up pic of the area where the pipe connects to the back of the stove.
    Also, since there isn't any clean-out T that I can see, how do you clean the pipe?
    I also noticed that you don't have any surge protector on that wall plug....not good, unless you have a "whole house" unit.
  8. MommyOf4 Feeling the Heat
    Southern MD
    We have a large strip surge protector for now. Is that ok?
  9. UMainah Member
    Bangor, ME
    You shouldn't need that bracket. They're typically used outside when a length of pipe isn't supported. In this case both ends of pipe have support (stove & wall). You'll probably want to replace that lower 90° with a cleanout tee also.
  10. imacman Minister of Fire
    Those things that you buy to plug computers and things into aren't good. You should get something like this:
    http://www.amazon.com/Tripp-Lite-ULTRABLOK-Protector-Suppressor/dp/B00006B81D/ref=sr_1_1?ie=UTF8&qid=1353777949&sr=8-1&keywords=tripplite ultrablok
    Also, looking at the last pic, I do NOT see an appliance adapter on the back of the stove....that is NOT correct, and could lead to a leak. Hopefully, other members will chime in if i'm correct on that.
    This is what it is supposed to look like:
  11. boosted3g Member
    Central PA
    I dont kow if its an optical illusion or just the pic but does it look like the pipe is going downhill right at the appliance adapter? To me the vertical pipe just dont like plumb either.
    SmokeyTheBear likes this.
  12. imacman Minister of Fire
    Since I can see the label on the pipe, take a close look....does it say "Appliance Adapter" on it? The part number should be something like "3PVP-AD".
  13. imacman Minister of Fire
    I thought the same thing....might be optical illusion as you said.
  14. MommyOf4 Feeling the Heat
    Southern MD
    I just checked and there is an appliance adapter. It looked like one piece until you get a closer look. The part with the sticker seems to be the appliance adapter, unless I'm wrong?
      File size:
      1.2 MB
      85
  15. MommyOf4 Feeling the Heat
    Southern MD
    All I can see is 3VP -PC pipe connector
  16. MommyOf4 Feeling the Heat
    Southern MD
    It does seem to go down a bit. :(
  17. imacman Minister of Fire
    Well, it's a little tough to see, but that might be an appliance adapter. Still isn't 100% right....needs screws to properly secure it (see my pic above....see black screw next to extra silicone I added around adapter). There should be 3 screws positioned around the adapter.
    As Umainah mentions above, that first 90 degree elbow need to be replaced with a clean-out T...otherwise you'll have ash build-up and no easy way to clean it out.
  18. MommyOf4 Feeling the Heat
    Southern MD
    Are there specific screws that you drill into it or just any screw will do?
  19. MommyOf4 Feeling the Heat
    Southern MD
    Can someone post a pic of your clean out pipe area?
  20. MommyOf4 Feeling the Heat
    Southern MD
    Do you need a fireproof insulated thimble or just a regular thimble?
  21. Woody1911a1 Member
    Marblehead , Ma
    to me from the picture it looks like they used plastic drywall anchors and they melted and the screws pulled . Mommy can you confirm that those screws screw into small plastic pieces in the wall or not ?
  22. imacman Minister of Fire
    Usually self-tapping screws will do, but regular sheet metal will work too.
  23. imacman Minister of Fire
    No anchors....see post #4
  24. MommyOf4 Feeling the Heat
    Southern MD
    There are no anchors, just the screws.
  25. MommyOf4 Feeling the Heat
    Southern MD
    So let me get this correct...
    1) adapter goes on the pellet hook up thing
    2) Clean out tee
    3) Venting pipe up to the thimble
    Right?
    What's next?
    Sorry I've been watching our new guys re-install this and things keep coming up. I just want to know, I feel like I should install it myself! <----coming from a clueless person
