I was thinking of getting a portable generator for back up for my Harman p61a. Not looking to spend crazy amount of money. I was wondering if anyone here uses one? How many watts would I need?
From my understanding it's pretty standard to use a pure sine wave UPS with our stoves, so why do we need a pure sine wave generator when the generator will be passing electricity through the UPS which will then regulate the output?
Did the Harman & Heatilator run OK on the XP8000?We have a Generac XP8000e to power everything else during long outages
If you DO get one, whatever you get, make sure you exercise it. Take it out every so often, put fresh gas in it, and run it with a load on it. Generators don't like to just sit around, and you want to make sure it runs when you need it to.
Warning: Soap box rant approaching... Best bet for any of us: Check with YOUR stove mfr to see if YOUR stove requires a sine wave, near-sign wave (i.e., stepped), or just a plain old modified sine wave generator. Saying "it worked for me" in this subject area, unless someone else has the same stove model (MAYBE same mfr) OR unless a person is just recommending a sine wave gennie (admittedly more expensive), is not much different than comparing eyeglass precriptions. What works for one may not work for another.
A true sine wave generator will always work, of course, if it produces enough wattage (and almost any will, as stoves don't take much). But sending someone off to buy anything less is a roll of the dice, but with their money. Electronics can be damaged, and/or someone can end up with no heat when they need it most. People are easily confused in this area, confusing things like wave form with surges, as we see here. Send them off to THEIR mfr to get facts rather than opinion. Stepping off soap box now...
My UPS display says about 430W when my pellet stove igniter is on. I just added a Yamaha EF2000iS Inverter Generator into my backup plan. They are very similar to the smaller Honda models, except they're blue. This little thing is very quiet. We use it to run the pellet stoves, the TV, a few lights, router, and phone chargers. We have a Generac XP8000e to power everything else during long outages, but during the ice storm of 2008, we noticed that it was running all day to mostly power about 500-800W of stuff, hence the addition of the Yamaha.
Some considerations - do you want to power other things with this? Do you want to power the necessities in your home during a long outage? What's your price range? Chinese knock-offs can be had for a few hundred dollars, and they work just fine in a pinch but I've heard stories around my area of folks frying their well pumps with them.
Do you know if these folks that fried their pumps were using an appropriately sized generator? Those well pumps need outrageous amounts of surge watts to get them going and a generator that is too small would not be good. I have read virtually every blog, review and know people that have a Chinese knock off, including myself and the results are overwhelmingly positive when used correctly.
I am not sure what you consider a crazy amount of money, but I second the Honda Eu1000i inverter generator. I have a EU2000i and love it. They are so quiet, and efficient. I have always tried to purchase power equipment with Japanese engines (Honda, Kawasaki, Maruyama). In my experience, they are worth the extra money.
Yamaha generators are nice as well.
I used a meter to determine the actual power consumption of my XXV, and it was well below what the manual states. If I remember correctly, I was able to start my stove, run my 60" plasma and cable box, for under 500W.
You should certainly be fine with 1000W of output.
Your description may be technically accurate, but as used in normal conversation, the output of an inexpensive generator is anything BUT a sinusoidal wave, which is the normal definition of a "sine" wave as commonly used. And those less expensive gennies are commonly referred to, at least in my part of the world, as "modified" sine wave gennies. I suppose it would be more accurate to call it a "squared waveform", but it is not a "sine" wave if you take that to mean the smooth, repetitive oscillation we obtain from utility power or a true/pure since wave generator.Good post....just wanted to clarify that regular generators are not a "modified" sine wave. That term is used when using an inverter from dc to ac. Regular generators produce normal sine waves, just not perfect or pure like a "pure" sine wave inverter would.
